#136
Sorry I'm retarded I counted 37 not 38 sorry. Meah O2 Sensor is gonig out. Need it replaced.
1994 SVX L - FWD Barcelona Red 190K miles ~ SOLD 1994 SVX LS - 5spd AWD Emerald Green 202k miles PWR Radiator, HID 5000k, New paint job with issues, 17" STI BBS wheels, converted to 5spd AWD from FWD. Purchased from SVXyGirl 2/20/09 -- Undergoing complete rebuild 1993 Justy 4wd 5door- Teal of sorts , beater. 2008 OBXT Newport Pearl 65k miles |
#137
Well, it's good that it wasn't a faulty mod install.
![]() ![]() Enough expensive things happen to the SVX without adding to the grief. ![]() Pleased you got to the core of the problem. Joe
#138
Power mod works on 97!
The power mode works! Now the ride to reading will be more fun!
![]() 1997 Ebony #308 113k "The Black Diva"SOLD ![]() 1992 Black over Liquid Silver 152k SOLD ![]() 1992 Ebony 251k 444 SOLD ![]() 1999 Silver SLK230 134k SOLD 1997 Green Outback 137k SOLD 2013 Honda Accord I4 SOLD 2015 Subaru Crosstrek 30k 2018 Tesla M3 30k |
#139
Yay! Great when it's just something simple in the way, eh? Enjoy the mod.
#140
Yeah but my check engine light on pops on for 30secs to a min. But again sorry for assuming it was this, I thought I counted right but I had some more time and sat there for 15 mins reading it.
#141
![]() Quote:
Now we have proven that the Power mode mod works on all SVX models from 92 all the way through to 97. Great work man! Thanks for the help. It will be good to see your pictures, and I hope you enjoy Reading. Joe ![]()
Black Betty [Bam a Lam!] '93 UK spec, still languishing Betty Jersey Girl Silver '92 UK [Channel Isles] 40K Jersey Girl @ Mersea Candy Purple Honda Blackbird Plum Dangerous White X2 RVR Mitsubishi 1800GDI. Vantastic 40,000 miles Jersey Girl Last edited by svxistentialist; 04-19-2008 at 04:57 AM. |
#142
Many thanks!
Thank you for the kind words, I want to thank everyone here, for thinking this up! this is by far the best mod I've done yet, although I have only done a few...I have the smallcar shiftkit in all 3 SVXi, I don't think you need or want it with the power mode. my reason for getting the shiftkits (before I read through all the negative posts here) was the flare between gears under 1/2 throttle. I am going to try disconnect/ jumping out the shift kit and see what difference it makes.
Other mods I have is the intake resonator removed on my daughter's (sweet sound, no power increase) and the ECUtune v1.5 (crisper response) but this mod really wakes up the car. With the 4.44 (my next major mod to my daughter's car) this must be awesome.
#143
Just curious. ![]() |
#144
Intake resonator was dirty, but low skill level
![]() jackup, remove pass side wheel, peel down front wheel cover, WD40 the nut/bolt on the small fender brace and carefully remove, remove IIRC 3 or maybe 4 bolts...I used the write up found searching here, it wasn't hard. I didn't do anything with the intake pipe yet, presently sucking hot air...at the time, didn't want to hackup the resonator, it really is a nice piece of engineering. I was going to fab something. I took resonator off at Thanksgiving time in CT, wasn't very worried about hot air... hope to see some good examples at at Reading tomorrow! VERY sweet sound, OTOH I grew up wanting a Porsche...
![]() 1997 Ebony #308 113k "The Black Diva"SOLD ![]() 1992 Black over Liquid Silver 152k SOLD ![]() 1992 Ebony 251k 444 SOLD ![]() 1999 Silver SLK230 134k SOLD 1997 Green Outback 137k SOLD 2013 Honda Accord I4 SOLD 2015 Subaru Crosstrek 30k 2018 Tesla M3 30k Last edited by processengr; 04-18-2008 at 08:58 PM. Reason: spelling/drinking |
#145
O.k I visited my local Auto Zone to get a simple Toggle Switch and Using some Speaker wire I had around and put it in the driver side handle. Where the hand is put to close the door. it doesn't sit right but I will mess with it tomorrow or Saturday. But the Switch works on command. I need a smaller switch Length wise, as it hits the metal. Again not the best place but its the only place I could think of that didnt require dismantling the car or the Manual Button. Ideal spot would be where it is put JDM but untill I can get free time. >.> I wanted the mode but I didnt want manual button outta use. Of course a switch to control which it sends ground to would do. O.k enough thinking sleep time.
#146
Re: Power Mode Selection
Can you? or has anyone used a 12v lighted mini rocker switch for this?
http://www.allelectronics.com/make-a...-SWITCH/1.html Something like the above?
1994 subaru svx le 112k |
#147
The pins on a lighted rocker tend to be 1-power, 2-switched-power, 3-ground. It might work if you reversed it: 1-ground,2-switched-ground(TCU),3-power. But it depends whether the light inside is a simple bulb or an LED. You don't really need a lighted switch because the power light on the dash will come on.
Subaru ECU and TCU Website 1992 Alcyone SVX Version L 1992 Alcyone SVX Version L 1994 Alcyone SVX S40-II 2004 Subaru Legacy 2.5 SE Sports Tourer 1996 Subaru Legacy 2.2 GX Wagon 1988 Subaru Justy J12 SL-II |
#148
#149
Looks like I'm reviving an old thread, but its relevant to my question. After reading this I'm thinking I might want to try this mod, but I suppose I should figure out if I have a problem first. When I start my car and all the lights come on, the power light does in fact light up. But I have not been able to get it to light up while driving, and it seems to me as though my shifts are not responding as they should. When I floor the gas I get the acceleration I expect, but the tranny doesn't shift into second until after the tach hits the redline. Seems to me that its shifting a lot later than it should, and its revving up so much that it practically skips 2nd gear. Any ideas? (Keep in mind this is my first auto tranny, and I'm not exactly sure if its doing what it should or not.)
92 LS-L, Ebony Pearl, 160k miles, sitting in the hospital waiting room hoping for a miracle 06 Hyundai Sonata GLS, 77K miles |
#150
Try taping the gas to the floor and see if it comes on.
