Old 11-08-2012, 06:16 PM
Originally Posted by SVX8588 View Post
I was thinking it might be the Idle air control, but I haven't had time to research it.
Good luck with the PCV valve. I did mine earlier this year, and I was able to do it with regular tools. I think I used a 3/8 ratchet with a deep socket but I can't remember for sure. I don't recall it being particularly difficult, but then again I had more working room since I had some things out of the engine bay to do the valve cover gaskets.
I think if you remove the throttle body, with the IACV out of the way you can get to it with a ratchet. At least that's my guess based on looking at my engine that's on a stand. In the actual engine bay it might not be that simple.
Old 11-08-2012, 06:18 PM
SVX8588's Avatar
SVX8588 SVX8588 is offline
Yeah, that's right. I think I did have the throttle body off at that point...
Glen
SOLD - 1992 LSL 180K #8588 with svxfiles' all aluminum radiator; Wolf's head synthetic ATF in tranny and power steering; lighted power mode switch; Mobil 1 10W30 motor oil with Bosch 72158 filter; ACDelco A975C air filter; Valvoline synthetic 75W-90 gear oil, Optima BlueTop battery
2002 F550 74K
SOLD - 2000 F450 215K
1987 BMW 535i 209K
1999 Yamaha SRX 700
Old 11-10-2012, 07:25 AM
Machined brackets to fit my Rotora 6/4pot BBK kit. Installation on Monday...
Old 11-10-2012, 05:18 PM
Waxed both cars.. Installed snow tires ..cleaned out garage, put all the motorcycles to bed for the winter. Ready for winter
Old 11-10-2012, 09:40 PM
ShaneHobson ShaneHobson is offline
Washed it for the first time since it was repainted. Amazing how smooth it feels when wiping a wash cloth over a freshly painted car.
Old 11-11-2012, 08:29 PM
SUPER SUPER is offline
Today I installed my new OEM driver's side headlamp and combination light assemblies. Also used some sealant on the driver's side rear combination light assembly.
Last weekend, I replaced the seals of the rear combination and center light assemblies last weekend and it did not completely work on the combo assembly. I was still getting some water. Also replaced trunk and hood struts with OEM struts.
Just got my SVX a couple of months ago and trying to get it in top shape.
I think my next project will be stereo upgrades... I am low on $ tho for a little while. Hopefully by the end of the year. OEM parts expensive.
Old 11-13-2012, 11:47 AM
Chuckls's Avatar
Chuckls Chuckls is offline
Designated Asshole
installed UEL
Old 11-14-2012, 08:03 AM
theflystyle's Avatar
and where did you get that
1994 SVX LSi
2008 Legacy 3.0R
Old 11-14-2012, 01:40 PM
dcarrb dcarrb is offline
Silver SVX: Front axles, ball joints, ceramic front brake pads, machined front rotors, Bosch relay starter circuit mod (finally).
Every time I sink a little money into the thing I figure, well, now I've gotta keep driving it.
dcb
Old 11-17-2012, 01:37 PM
New foam gaskets in tail light bar and right side tail light. New wiper blades front and rear. Washed and vacuumed. OEM winter wheels back on.
Old 11-20-2012, 05:59 PM
Old Davy's Avatar
Old Davy Old Davy is offline
Another 50 F sunny day.
Tackled the driver side speaker grill, which had large blotches of rust at the top and completely orange on the bottom half, probably from a drink spill which pooled in the inner rim and wicked up the inner thin cloth backing. The Passenger side grill is flawless.
I've had the door panels off several times (new speakers & regulator/stabilizer adjustments) and there is no rust whatsoever inside the door or drain holes.
You folks will know the oval grills are a 3-layer sandwich of outer pierced metal screen, a layer of thin acoustic cloth and that tabs on to the inner plastic grill, the whole sandwich is then tightly speed-washered on to plastic posts of the door card. I was loath to break those posts getting if out.
So I went with surface stippling with foam block using two colors of paint. Didn't want to just mask and spraybomb it as it would have clogged the cloth backing screen.
Matching the color was trial & error with about 5 colours easily wiped off with alcohol until I hit the match. Funny color that has a Purple tint to the Taupe. Nothing in automotive came close - too light/too dark/too red.
Wish I'd taken a before pic that showed how horrible it looked - whenever I would look down the rusty orange was taunting me in an otherwise pristine interior.
Lawn furniture colours used - dark Taupe with a light layer of 'stainless steel' stippled over. Further stippling as it dries eliminated the 'silver' caste leaving the base color matte. Undetectable in real life, it matches the passenger side and I'm well pleased. The flash makes it look 'metal-y' - must take daylight picture.
1997 Ebony Black Pearl LSi, 80k miles (129k kilometers), JDM clear corners.
1994 Laguna Blue Pearl LSi, 149k miles (249k kilometers), blown tranny, likely using bits and selling as donor transplant project.
2006 Newport Blue Outback XT Ltd 117k kilometers, lowered 2.25" on OEM Legacy GT suspension.
1994 Emerald Pearl LSi w 2006 WRX 5 spd manual.
1997 Laguna Blue LSi, 46k miles (73345 Kms). One owner 25 years, always garaged, pampered and 9/10 showroom condition. Possibly the last Canadian spec Laguna ordered #100134
Old 11-21-2012, 02:45 AM
Took my Vortex XT6 for a drive for the first time in several months. Wow, what a pleasure. Amazing to drive a car that is 25 years old with cruise control & ABS brakes.
Old 11-21-2012, 04:47 PM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
Put on my winter wheels/tires, and put some new headlights in. Did the 9005 to low-beams mod and put yellow fogs in. I also used that 3M headlight restore kit, the one that's used on a drill. I had enough to do my car and my in-law's.
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 11-21-2012, 04:56 PM
SVX8588's Avatar
You need black lug nuts to go with those wheels!
Car looks sharp, btw.
Glen
2002 F550 74K
1987 BMW 535i 209K
1999 Yamaha SRX 700
Old 11-21-2012, 05:12 PM
B 4 You's Avatar
#lolsvx
Thanks! I actually intentionally kept them chrome/rusty silver... I like it better than black on the stock wheels. I removed the center caps too. It kinda makes them look like different wheels
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
