Old 11-21-2012, 06:35 PM
Originally Posted by B 4 You View Post
Put on my winter wheels/tires, and put some new headlights in. Did the 9005 to low-beams mod and put yellow fogs in. I also used that 3M headlight restore kit, the one that's used on a drill. I had enough to do my car and my in-law's.
You should buy something to protect the headlights. UV clear or clear vinyl.
Old 11-22-2012, 06:43 AM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
I'm putting all my accessory belts, changing oil, radiator and coolant today and the SVX should be idling
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 11-22-2012, 07:55 AM
Bought new winter (WeatherTech) and summer (factory) floor matts for the Spec B, and picked up a new driveshaft for the SVX. Need to get that swapped in and then I'll have a properly driveable car again.
Old 11-22-2012, 08:31 AM
theflystyle's Avatar
i was looking at the weathertech mats but unless they changed recently i didnt see that they had any custom patterns for the SVX. what did you end up getting/pics?
1994 SVX LSi
2008 Legacy 3.0R
Old 11-23-2012, 05:59 AM
Tim's Avatar
Tim Tim is offline
Got my SVX running yesterday afternoon and was able to drive it off the ramps for the first time. Completed my year long project of:
new steering rack
idler pulleys
waterpump
thermostat
timing belt
all new vacuum lines
clean throttle body
spark plugs
new red top
new starter
new exhaust donuts
valve cover gaskets
drain and refill manual transmission gear oil
replace drivers side CV axle
Probably didn't need to pull the motor but it made it easier to do it in the comfort of my garage. It probably shouldn't have taken a year either but I traveled over 40k miles for work back and forth between the east coast and west coast. I'm also not the most mechanically inclined so had to research through the FSM and the manuals. I had forgotten to re-tighten the water pipe under the manifold so there were times I had to pull it all apart to re-tighten. At least I learned a lot
Everything is back in and running smoothly. Drove it off the ramps it's been sitting on. I popped a brake line in the rear a few months back and I'm going to investigate today if it's the hard line or a rubber line. Thanks to YT, OT and Nate for their guidance along the way.
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 11-23-2012, 09:17 AM
congrats on the completed job. that has to be a good feeling.
1994 SVX LSi
2008 Legacy 3.0R
Old 11-23-2012, 09:39 AM
Tim's Avatar
Tim Tim is offline
It was! Now I'm debating between trying to see if I should tackle the line by myself or having it done. It's like it's so close I can taste it!
Below is the line on the left hand side. Looks like I should b able to do myeslf.
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 11-23-2012, 03:39 PM
Old Davy's Avatar
Old Davy Old Davy is offline
Quick head's up because I've done the look-see in person at Weathertech Canada outlet. I hoped for Floorliners like I have in the Outback.
WeatherTech did not introduce Subaru Floorliners until 2005 and didn't bother with the SVX pattern. They do make fitted Floormats for the SVX but they are much too small to protect the carpet edge areas.
Best to get some generic Pants-saver mats for winter. Same for summer unless you actually like carpet mats (not up in messy Canada for sure)
1997 Ebony Black Pearl LSi, 80k miles (129k kilometers), JDM clear corners.
1994 Laguna Blue Pearl LSi, 149k miles (249k kilometers), blown tranny, likely using bits and selling as donor transplant project.
2006 Newport Blue Outback XT Ltd 117k kilometers, lowered 2.25" on OEM Legacy GT suspension.
1994 Emerald Pearl LSi w 2006 WRX 5 spd manual.
1997 Laguna Blue LSi, 46k miles (73345 Kms). One owner 25 years, always garaged, pampered and 9/10 showroom condition. Possibly the last Canadian spec Laguna ordered #100134
Old 11-25-2012, 09:15 AM
wdb wdb is offline
dances with roads
I took my SVX for its first-ever (for me) longish drive, 135 miles round trip, including four-lane highways for the the first (for me) time. Wow, does this car have legs! It was just loafing along at highway speeds. And the acceleration from 3K RPM in 5th gear (I have a manual conversion from a WRX) feels just as quick as accelerating from 3K RPM in 3rd, which was very unexpected. I credit the slippery bodywork and low Cd for that, and for how quiet the car was at highway speed.
In some ways the SVX reminds me of my wife's long-gone Mercedes 300D sedan. The diesel felt sluggish at low speeds, and the steering was slow and lumbering on the tight, narrow back roads around here. But an on-ramp and some open road totally transformed the car. You could really tell it was built to cover large chunks of territory in the land of the autobahn.
I feel much the same way about the SVX. Compared with my STi and Honda Fit it feels a bit heavy and slow to react, and the steering isn't as quick; I'm not saying it's a bad car for those conditions, but it's not as engaging on the narrow twisties as my other two. Once the road opens up a bit more, the SVX's full character is revealed and it really shines. For me the SVX is a GT car, built to cover long distances rapidly, quietly, and competently. I was very pleased and very impressed. And I can't wait to do it again.
1995 Caterham 7 Twincam
2007 BMW 328i Cabriolet
2012 Tacoma 4wd v6 Access Cab
Old 11-25-2012, 01:30 PM
bishop bishop is offline
Sounds great wdb.
I installed my quick shift the other day and it really feels an improvement, shifts were much tighter on the highway.
Old 11-25-2012, 04:25 PM
100% agree with that. Horses for courses, the Svx was designed for the fast open roads, and long distance touring.
Old 11-25-2012, 11:27 PM
torxxx torxxx is offline
I took my SVX to the ice track and burned up a half tank of fuel over the weekend. 4.44+killer winter tires and -25F temperatures means great hookup. I think I was suffering some front wheel lift coming out of corners though, that was bout the only time I had a wheel break traction unless I was WOT
waiting on new pads/rotors/cv axles for the front, contemplating getting coilovers not sure if I can justify that kind of money on a 200k mile chassis/engine.
92 Svx 4.44 swap 198k miles. Toyo Garit KX tires.. my Icetrack car
86 Lifted GL wagon well over 600k miles on the chassis
98 Outback 5 speed 6 inch lift, forester struts/springs 29" tires
Old 11-25-2012, 11:44 PM
ShaneHobson ShaneHobson is offline
Drove my SVX to work today, same as I do every day. It's such a pleasure.
Old 11-26-2012, 01:14 AM
EdWindows's Avatar
EdWindows EdWindows is offline
5spd + coilovers = win :D
O2 sensor and window scratcher fix.
1992 Dark Teal LS-L w/ 165k+ miles (traded )
Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs
2001 Black Toyota Sequoia (hauler/daily)
1992 Blue Toyota Cressida (drift car)
1992 Red Toyota MR2 (weekend/track day car)
Old 11-26-2012, 03:44 PM
Svx95's Avatar
Svx95 Svx95 is offline
eg33svx95
Transmission was opened to fix awd system, pain in the ass to find the part needed, took over 4 weeks. Spark plugs replaced (NGK), New valve cover gaskets and head gaskets, 2 new belts, New timing belt, new idlers, new hydraulic tensioner, New water pump and gasket. New thermostat and gasket. Cut out resonator (rattling was so annoying when idling) and now just straight piped. New K&N filter, Oil change to full synthetic 10W-30. All the above was done in the past 4 months. Now there seems to be a problem with the the power steering pump, it whines when the car starts and when the steering wheel is moved. Just 2 days ago it burped SF at girlfriends parents brand new driveway!! I'm currently in college so I need to find some spare time with Finals and Holidays coming up; NOT TO MENTION THE COST TOO!! . Hopefully can diagnose and have it fixed by 2013!
Sam
Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners
