#1561
Re: SVX Engine cooling "Again & Again"
Seems summit racing has their own brand of radiators now. Cheaper than griffin too.
http://www.summitracing.com/parts/sum-380425/overview/ |
#1562
I don't think you understand how a dual pass radiator works...that would just cut off half of your radiator area.
![]() That diagram shows why you need inlet and outlet on the same side. If the outlet was on the opposite side it would be less effective than a normal cross flow. |
#1563
I do understand. I just don't want to pay another 200+$ for an aluminum radiator if I can just weld in a 1/8th inch aluminum plate to lead the coolant in a way which increases the effectiveness of my rad.
#1564
It's your welding skills ![]() Well, that and flow calculations based on the number of rows in each of your now 3 cross-over sections, and the cross-sectional area of each. |
#1565
Welding skills indeed. I can weld just fine thank you much. I haven't however, welded aluminum before and wouldn't be attempting to weld my radiator as my first attempt.
Just saying, I 'could' make my radiator truly cross flow. Even tho the inlet/outlet are opposite side. |
#1566
I must be confused then, where exactly are you welding this plate? Your Griffin rad is already crossflow isn't it? With the inlet/outlet on opposite tanks and diagonal from each other?
cheers -Evan |
#1567
Yep, however, if you let the car idle you can feel the outlet tank get hot as hell, as well as the first inch or so of cross ribs. I'm pretty sure it's sold as 'cross flow' and it isn't actually cross flowing. Seems the water is going in, straight across the top and down the outlet tank.
#1568
I have been wanting a reason to duct the hood. ![]()
#1569
Once you fix cavitation the limit on the amount of cooling is the airflow through the radiator. By the way if you want to run the Fan test idea suggested, with a SVX you need to have the AC turned off or the fan will run. Tony
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. |
#1570
When I installed hood spacers I rejected everyone's realities and used my own. Still thinking of yanking the spacers out tho. They do look mean, but my hood pins work better without them. (sorry cory)
#1572
Have removed
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. Last edited by Dessertrunner; 09-26-2013 at 12:12 PM. |
#1573
You could make an under-body aero tray that's open at the 'back' of the engine. It would suck air down if angled correctly. Decreasing the turbulence under the bonnet would help a lot too.
#1574
Rubber air dam hanging off / below as per many brand new cars. Low pressure created behind rubber sucks air out. |
#1575
So much so that we tested this. http://www.youtube.com/watch?v=yo1hboEl6Qg We found no evidence of airflow reversion, and I suspect that it has more to do with windshield angle than anything (old cars weren't the most aerodynamic anyway, and there's a reason that they don't use cowl induction anymore). That being said, there is an easy way to increase airflow, and subaru has endorsed this method: ![]() Although I would be curious how many people have the stock undertray still installed vs who has cooling problems. Another way would be to make sure that there's ducting around the edges of the radiator, forcing air through it rather than around it. |
