#1591
In the journey to cure the shuddering problem in my daily drive SVX, I jacked up rear of my parts car (from where the daily driver's transmission was sourced) and confirmed suspicions that it has a 4.44:1 diff.
Hatched a plan to put the parts diff into the daily driver, first step of removing the parts diff was completed A-OK. |
#1592
Put the shuddering car up on 4 wheel stands in anticipation of diff swap tomorrow morning to cure shuddering problem.
#1593
#1594
I sent you an email about tomorrow.
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything |
#1595
Fitted 4.41 rear diff. Shuddering problem solved !
Yay |
#1597
I'm a little confused by 4.41. I assume you mean either 4.44 or 4.11. But as long as your problem is solved, that's good.
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ![]() |
#1598
I'm just surprised that you can drive around with a mismatch diff and not break anything.
1992 LSL ebony pearl 170k - Thank you Ron Mummert Reading Box of Wine Car ----------------------------------- 1992 SVX LSL 5-Speed Sold at 180K 2019 1995 SVX Lsi Polo Sold at 118K 2007 |
#1599
I would be worried about damage to the center diff. But if all seems well then maybe it's fine. Probably depends on how long it was driven for and how far and fast.
#1600
I blew a center diff in a 5MT in about 4 miles when the wrong reduction gear was put in the transfer case. That was the dealership's fault thankfully, but it doesn't take long.
#1601
#1602
Handed mine over to OT so he could play with my crank.......seal along with the cam seals, timing belt, pullies, water pump, plugs and front struts.
#1603
Got rear ended.
Driving along a state highway, wifey asked "why is that guy reversing up alongside the road" about 500m away. That seems odd, as we got closer we could see he was reversing a trailer. Closer still, his trailer had dumped something in the middle of the road and the oncoming traffic was driving around it onto our side of the road (what we call a state highway here can mean a two lane road, one lane in each direction and no barriers separating opposing traffic). So I stopped, (gently, not locking up the brakes or anything silly) and eyeballed the situation to see if we should simply wait for traffic to clear or get out and help. I heard screeching tyres behind me, looked back to see a cloud of tyre smoke, guessed the person behind me was trying (badly) to stop in a hurry, so I gave my car some gas to move forward, hoping they would stop short of me. Not enough room, they still managed to hit me. Very minor damage to the rear bumper, nothing else. A bit frustrating as the whole car has just been panelled and painted. Just glad I saw what was happening so I could open up the gap, otherwise the damage would have been much worse. Funny thing is, the driver of the car behind me told me several times that it was my fault because I didn't have a good reason to stop (apparently a trailer load spilled into the road isn't sufficient reason to stop). Never mind, I have full cover insurance and she's a clown. More amusing she has probably put four flat spots on her tyres from the 50m long lock up (I measured it), so now she will here the constant sound of the flat spots on her tyres to remind her to pay attention to the traffic in front and not gaze off into the wilderness. Back to the panel shop. |
#1604
Shane - what a bummer, especially after all the work you have done recently - hope you have the car back on the road quickly.
#1605
Glad no one was hurt, even the SVX itself. It would have been a real bummer if the car was totaled.
Danny 1994 Silver SVX in hybernation, awaiting for the monsterous awakening (Lebanon) ![]() 1967 Mercedes-Benz 250SL Euro Specs, Hard/Softtop, White/Red. Under Complete Restoration ![]() 2013 Mercedes-Benz SL350 Euro Specs, White/Red. Mint... Another step into SL Collection. ![]() |
