#151
Re: SVX Engine cooling "Again & Again"
Tried pulling the fuses on the fans and reving the engine to see if the cooling is different between the heads. Bad news it didn't work as radiator just moved up at the same rate as the engine. There was not enough cooling to work. Even with the fans on it didn't work.
Tony
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. |
#152
![]() Has anyone tried a 35psi pressure cap to give more headroom for this pressure drop? May not solve the problem, but mask it enough for some. http://www.speedwaymotors.com/High-P...isplayId=13000 The major trouble with running the cooling system at elevated pressure is the reduction in flow from the pump. FT |
#153
I had dismissed the idea of local pressure drop cavitation because this is a closed loop, but I suppose that a local restriction which would require a large decrease in static pressure to accelerate the fluid to the required velocity through the restriction, which could conceivably drop the local pressure below the flash point of the fluid.
Assuming that the radiator cap isn't blowing, then the average system pressure is going to be below 2 Bar, depending where in the radiator cap is located in the line of pressure drop around the system. Let DP be the pressure drop through the whole circulation system; the amount of pressure the pump has to generate to get the flow. Assume the radiator cap is located halfway between (from a pressure drop standpoint) the pump inlet and the pump outlet. The absolute pressure at the pump outlet is going to be (2 Bar + 1/2* DP). The pressure at the pump inlet is going to be (2 Bar - 1/2 * DP) So, if the pressure drop through the system is 1.2 Bar, then the absolute pressure at pump inlet is going to be .9 Bar. If the water is a 220 DegF, it's boiling at that point, and the pump will lose flow, until the steam bubble passes or collapses and the pump rotor is fully immersed again. This could happen with a centrifugal water pump operating well above its design RPM, developing more flow against a system pressure drop that increases with increasing flow. So, we could have a negative suction head problem even in a closed system, when the fluid is operating at a temperature near its flash point.
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
#154
I like your ideas shotgunslade! I hadn't had my cup of coffee yet! I didn't realize I was looking at a closed loop system with the pressure cap just being a safety valve for overpressure conditions.
It would really be of great value to measure pump inlet and outlet pressure! Last edited by FriendlyTurkey; 10-06-2009 at 04:45 PM. |
#155
![]() The closed loop includes a radiator and the following does not normally apply.==== “So, if the pressure drop through the system is 1.2 Bar, then the absolute pressure at pump inlet is going to be .9 Bar. If the water is a 220 DegF, it's boiling at that point, and the pump will lose flow, until the steam bubble passes or collapses and the pump rotor is fully immersed again.”
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! ![]() Last edited by Trevor; 10-07-2009 at 03:51 AM. |
#156
The pressure to be considered is in no way related to the atmosphere. The pressure within the circuit depends on the pump output as is opposed to the available flow path.
Increasing pump speed against a fixed resistance/head, increases the internal pressure. This will constitute a constantly reducing pressure gradient. However, because of huge variations in resistance throughout the flow path, this will not be consistent. The lowest pressure will finally occur at the pump inlet. Flow will not increase in line with pressure. Pump speed, pressure, flow, will not increase in a linear fashion, far from it. In fact there is a final point whereby flow will choke at a maximum. Taking the above and all of that mentioned in previous posts into account, there is a point where pressure becomes an absolute disadvantage. It is very possible that this point coincides with approximately 5,500 engine RPM. Is there not strong motivation for a cheap and simple experiment involving reduced pump efficiency? ![]()
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! ![]() |
#157
The relationship with atmospheric is that the radiator cap will blow at some differential above atmospheric. The system is closed until that happens. The absolute pressure at the pump discharge may actually be above the level necessary to blow the radiator cap, but pressure drop between the pump and the cap may reduce it, so that the cap doesn't blow. If the absolute pressure at the pump inlet is below the flash point of the coolant, you will get cavitation.
If we know that the absolute pressure of the system at the radiator cap is below 2 Bar (the cap hasn't blown), we could calculate the pressure drop. If it is below the flash pressure of the coolant at whatever temperature the coolant is at that point, you will get boiling. In general, system pressure drop follows the equation: (where DP = pressure differential, K is a consant and Q = flow) DP = K * Q**2 So, yes, ieven though the system pressure drop increases with the square of the flow if we are running the engine way above the lnormal rev range, the pump will still have increased flow with increased rpm, even though it is only increasing at less than the square root of the rpm increase. Pressure drop across the ystem will be increasing drastically. Assuming the cap hasn't blown, the system flow pressure drop between the cap and the pump inlet could make the absolute pressure at teh pump inlet less than the flash pressure of the coolant at that point.
#158
Remember the old cars with something called a fan clutch? They operated the mechanical radiator cooling fan on a hydraulic disc such that when it achieved a certain load (or rpm), it couldn't spin any faster...this sounds like something we should try with the water pump...above certain RPM's it becomes a fixed speed.
We can do this with electric pumps, but not with the mechanical one. If this is the case, why have the people who have dabbled with electric pumps (I can think of a handful), not been able to achieve a solution? I've procured a BMW water electric water pump in an effort to solve some of this. Based on everything I've heard, my collection of ideas to solve this is: 1) Dual top outlets, separate from each other (like the current six cylinders) 2) Alloy radiator - (PWR or similar) 3) Electric pump 4) Gutted original pump to operate just like an idle pulley, but paying particular attention to flows in and around the original pump 5) Heater system removed - to avoid complications 6) Throttle body water heating removed - to avoid complications 7) Dual high air displacement fans 8) Engine oil cooler 9) Modified thermostat When will I do this all...hopefully over our summer break...but slowly. Cheers, Matt |
#159
Electric pumps have proven only to be a bandaid to the cooling issue. it makes it better but does not address the real issue at hand.
Tom |
#160
I agree with Tom at this point in time there is no evidence to suggest that the pump is the problem.
As regards pressure in the system, a higher pressure can only happen if part of the coolent system has a restriction that decreases the flow. Any potential pressure restriction is likly to be with in the engine which would mean that there is a potential vacum on the radiator side of the circut due to the pump suction. Having driven for the last week with the 3 temp guages there has to be a major problem with the flow in the left bank. Every time I look the two heads are showing near 10c difference. I agree with the general opinion that the next work needs to be on the top pipe. The recent discussion leads me to think that I need to find a way to fit a pressure guage or is it correct to assume that Temp is flow. Is the current thought that the left and right heads have the same coolent pressure. I personally think they would be different due to the reduced flow between left and right but am open to correction. Tony
#161
While I agree with Toms approach to use two pipes to a two inlet radiator, it may be beyond the possibility's of the average member. I agree it is best to keep using the std pump, till we find if removing the restriction will solve the problem, as most people would be using the std pump.
I think there is merit in Tony's center tap of the pipe, to remove the restriction and provide equal flow, as far as we can. If the modded pipe was provided with a center divider to direct the flow from each side to the outlet pipe, each side would have the same resistance, and flow the same. I bit like this. May not be too hard to do . Harvey.
#162
add a third small hole to each side... Open up a block and you will see why.
Also, remember making them equal on top means they are unequal as a system. it would be best to run both pipes on the RH side of the engine. The coolant has to flow into the block farther on the RH side so the make it as equal as possbile having a shorter exit would essential try to balance the two halves out Tom |
#163
![]() The bottom may be uneven, but it is the top outlet that is causing the main problem. If we can get that as even as we can to eliminate the problem there, we can see if there is a need to go further. Harvey.
#164
by creating one leg longer than the other you are essentially causing less resistance in the shorter leg and we are back at step 1.
Tom |
#165
However at the pump inlet, the coolant has been cooled by the radiator so that at that point, under normal circumstances, the coolant will not be boiling. As previously pointed out, the radiator must be taken into account. Quote:
![]() However no one appears to appreciate the consequences of this issue, and it therefore remains ignored. ![]()
