#1636
Gave the Legacy's engine the Scrubbing Bubbles treatment. I'll probably give it another round soon to clean some of the more stubborn areas.
Before: After:
#1637
Wow you're good
1992 LSL ebony pearl 170k - Thank you Ron Mummert Reading Box of Wine Car ----------------------------------- 1992 SVX LSL 5-Speed Sold at 180K 2019 1995 SVX Lsi Polo Sold at 118K 2007 |
#1638
How many loans did that take???
Glen SOLD - 1992 LSL 180K #8588 with svxfiles' all aluminum radiator; Wolf's head synthetic ATF in tranny and power steering; lighted power mode switch; Mobil 1 10W30 motor oil with Bosch 72158 filter; ACDelco A975C air filter; Valvoline synthetic 75W-90 gear oil, Optima BlueTop battery 2002 F550 74K SOLD - 2000 F450 215K 1987 BMW 535i 209K 1999 Yamaha SRX 700 |
#1639
How did they do on the windshield ?
When I was in school I sucked in sports. Then I found out I can buy trophies and now I am great at everything. |
#1640
Summer tires are back on since winter tires are falling apart and its warmed up a bit.
1992 SVX Pearlie: AmsOil signature synthetic 10w40 and Ea15k20 filter, Cobb crank pulley, Outlaw Engineering spacers and tb bypass, LGT 5spd, Slotted Crossdrilled rotors and ceramic pads, 11:1 compression, EGR delete, Port & Polished heads, SaikoMichi catch can, A/c delete. |
#1641
is that your daily driver? Thats kinda of an early move no?
Thats funny though since Im currently shopping for some Firestone Winterforce (not a DD)
1994 SVX LSi JDM Tailbar and Grill, Clear Corners, 15min-mod, Nevin Blue RSB, G-FORCE SPORT COMP-2 Tires, Phenolic Spacers (Manifold & Throttle Body), SS Brake Lines, Maniac Electric Motors 160A Alternator 2008 Legacy 3.0R |
#1642
Found out snow tires are 14 years old and starting to seperate so im only using them if there is ice or chance of snow, also they vibrate like crazy at 60.
#1643
14 years old? I wouldn't even use them for a tire swing. I thought I was bad trying for a final year 7 out of mine which show just minimal sidewall cracking on one of them but they're also $300 a piece.
British vehicles are my last ditch attempt to keep the nasty Italian thoughts in my mind at bay. So far its working. |
#1644
Sold my Teal on Wed, I am SVXless
#1645
#1646
I never did really care for this one like I did for my Ebony.
I'll wait and keep looking for another one, they show up about twice a year around here. |
#1647
Picked up a new turbo for the Legacy, a VF52. It's the OEM turbo on the 09+ WRX and a direct bolt on for my car. With a tune and supporting mods it's capable of 280-320 WHP.
#1648
installed Subaru reman FWD trans, alternator, couple hoses, radiator, trans cooler, speed sensor. Come to think of it, only other things that have been replaced are timing belt, water pump, brakes, rotors. 123k FWD.
1994 SVX L FWD "The Blue Bullet" |
#1649
I went to visit my baby today. She is still captive at the Transmission shop
I miss her
Father of 5 sons and 1 daughter Subaru SVX for fun Hyundai Veracruz for the wife. Susuki SX4 for my older son Ford Ranger for work Mercedes Benz Sprinter for vacation trips, EZ GO Golf cart for driving kids around gated community. |
#1650
Picked up the refinished JDM BBS wheels from Transwheel. Refinished back to factory specs. The original finish had changed a lot compared to the BBS original color when new and when compared to a new BBS wheel they have in stock and new center caps.
They said it wasn't that the color itself had changed that much, but the 16-year old clearcoat had yellowed a lot with age. Outer rims will be satin-polished instead of a high-polish, and the mesh will be painted with correct BBS-code silver and crystal clear powdercoat over everything. Got the correct lug nuts and locks to fit under the new center caps. Also waiting on new BBS valve stems. They will be at Reading. Ask Green1995SVX how much the pearl color changed when he put on new clear coat over the new OEM pearl paint on his 92. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 03-02-2013 at 10:44 PM. |
