#166
Here are the pictures of the last fabrication work i did before i switched to tuning and parts procurement.
Here's the paper templates glued to the sheet of 6061-t6. We use this annoying expensive alloy for our flanges because it is hardened and keeps a very flat surface excellent for flanges. Using the paper templates lets us keep very tight tollerances in alligning up our bolt holes while letting us make rougher cuts and not have to allways be worying about what edge is our straight edge etc. ![]() Here Is one of the flanges cut from the plate now on the drill press getting ready to have the pilot holes drilled for the bolt pattern. ![]() And here is one of the flanges after I've drilled the bolt holes and milled out the opening for the inlet. This is actually going to be a reject because i milled out the actual shape of the supercharger inlet(that was an expensive piece of metal to waste). I'm pretty much positive i won't be able to get away with that. I have a 3d image in my head of how the inlet side is going to work out at this point and that's not it. We'll get to that later on though. The next step is the bottoms of the outer sections and then the discharge flange. ![]() |
#167
On the tuning end I have also made the exact measurements for the z32maf meter. I had done this in a ad hoc fashion before which let me get a close enough estimate to work but now I've gone back and done the precise stuff to get a final version.
I'll go ahead and let the cat out of the bag now. We are ixnaying the nitrous tuning as stage 2 and using that name to release the software I just finished for the z32 mass air meter. The Stage 2v3 software is the same as the stage 1v4 software except that it uses the z32 mass air meter. This will allow the 2nd set of code which is switched to by the power input to be used for either 87 octane fuel or for forced induction. It isn't tuned for large fuel injectors like the stage III software but it is still a giant leap forward for anyone trying to make their svx faster than stock but unwilling or unable to step up to a full stage 3 system. It will accurately measure the air flow and thus propperly adjust ignition timing at any load and accurately control the fuel injectors right up to full open all the time. |
#168
Do you have a price on the new stage II? (1.5
![]() Would you be providing the MAF sensor? So does old stage II become stage III and old stage III become stage IV?
#169
All the information will all be on the website soon as I finish the site changes.
No, the old stage 2 which was nitrous tuning will no longer be offered. Stage 2v3 will be available on it's own, as an upgrade for stage 1 owners, and with the maf meter and electrical connector. Stage 2v3 package $429 Stage 2v3 upgrade $329 Stage 2v3 package with z32 maf and electrical connector $647 |
#170
#171
So it is the stage III chip, and MAF. Just w/o the fuel injector constant being changed for larger injectors? Are you willing to sell a version of that(modified constant)... If so I'm very interested as I'm deciding on fuel and tuning issues for my just purchased turbo.
1995 Subaru SVX -Accel Green Filter * -Flowmaster Exhaust -ECU Stage 1 Chip * -Alluminum Drive Pulley * -Stage 1 Shift Kit -Small Car Clear Lenses and Corners -1997 SVX Grill -17" X 7" Enkei Shoguns *Thanks Dayle! (SVX Motorsports) 1987 Pontiac Formula 350 -Enough ![]() |
#172
Know what I mean...either you are ready for stage 3 or you are ready for stage 2. There is no stage 3 at a stage 2 price. If it could be done I'd be doing it. I strive to produce what the demand is there for after all.
Michael Emery, MBA, MS 94 SVX LSI, Ebony Pearl profile 94 SVX LSI, Ebony Pearl from back Performance and Multi-Fuel Tuning Last edited by longassname; 07-13-2005 at 07:31 PM. |
#173
I little clarification, please. For those of us who already have the Stage 1 v4 chip, exactly what will the Stage 2 v3 provide if you don't have the z32 MAF? Thanks. -Bill
#174
big clouds of smoke if it will start. Stage 2 is for running a z32maf meter; if you aren't going to run a z32 maf there's no reason to get it and it wouldn't work anyway.
Michael Emery, MBA, MS 94 SVX LSI, Ebony Pearl profile 94 SVX LSI, Ebony Pearl from back Performance and Multi-Fuel Tuning Last edited by longassname; 07-13-2005 at 10:08 PM. |
#175
So wait. The new stage 2 is $100 more than the old nitrous setup but yet offers nothing to the N/A community?? That makes no sense except for people like SVXtacy and Svxfiles. I too would like to build my own S/C setup if I stumble upon some "cheap" parts but I don't see it happening for me. I think any credit towards purchasing the stage 2 that I was gonna buy has gone to waste now. Is there anyway I can still get it or are you completely done?
Tom |
#176
Tom, Have I ever left somebody unhappy? Of course I'll still be happy to supply you with the nitrous version. I'm not going to keep carying it in general but no reason i can't provide it to you. I wouldn't say it offers nothing to the N/A community either. It's beneficial to people who want to run higher rpms. There will probably be a performance increase for all svx's. Someone else is planning on testing that so I'll let him share his findings when he does instead of me doing it. |
#177
OK Mike, you scared me for a minute. I was thinking of retracting my offer for IRIS valves.. I still need to ship them. With all of the parts I have sent you, how much would the stage 2 software cost me at this point??
Tom |
#178
![]() didn't we already discuss what i'd give you? Anyway, no more talk about stage 2v3 here. This thread is for those who purchased stage 3. I'll start a stage 2v3 thread soon. |
#179
Is there any estimated completion date for stage 3 yet?
#180
