#1846
#1847
The cooler is built into the radiator. I just used a 3/8" piece of metal tube and clamped both lines to it. After driving it hard putting over 100 miles and about 3 hours of driving, the shifts stayed the same. I'm sure on a hot summer day it won't be happy and that's why I'll be getting a cooler for it.
#1848
Have a look at Jaguar Liquid Silver. That's what I painted my wheels.
http://www.subaru-svx.net/photos/fil...BABY/44245.JPG Hi res pics in my "Old Locker"
Peter ART Cryogenic/Slotted Rotors, Stainless Steel Brake Lines, PWR Radiator, Tranny cooler, Stebro, Earthworm's Poly Differential/front & rear swaybar bushings, Koni Inserts and Mychailo SVX Sport Springs all 4 corners, Indigo Blue paint. Liquid Silver Wheels. |
#1849
The problem is the deep outer lip makes the silver look darker and duller in the shadows. Same with the sharp angles of the spokes. Our stock rims don't have such a deep profile and being more solid, reflect more light. With the duller outer rim, your focus is now on the center basket, which makes the wheel look smaller. Even duplicating the painted outer edge of the wheel with the same silver did not help to define it. Transwheel was going to try to machine the deep lip, but the tight curve at the base of the lip, where the mesh starts, was too small for their finest tool to fit in without risk of damage. Such a high positive offset (+55mm) for this kind of wheel is unheard of. When svxcess is happy, everyone is happy... Now to decide if I want the center hex cap to be aluminum plated or chromed (yes, they can do that to plastic) or leave them be. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 05-05-2013 at 01:48 PM. |
#1850
Might mot be your taste but have you thought of this.
http://wheelsnob.com/?attachment_id=80
"The things you own end up owning you. It's only after you lose everything that you're free to do anything." 92 Pearl White Ls-l (138k) Euro Headlights & Blinkers, 97 Grill, Euro Tail Lights, SS Brake Lines, Stebro Exhaust, Slotted Rotors, Classic Registration 96 Legacy Outback (206k) 5-speed 2.2 Lightweight Crank Pulley, Group N Trans & Motor Mounts SOLD Wanted: Steering Wheel Last edited by michael; 05-05-2013 at 08:11 PM. |
#1851
Picked up SMC's rebuilt 11.5:1 engine and had lunch with him, great to meet and hang out with.
1992 SVX Pearlie: AmsOil signature synthetic 10w40 and Ea15k20 filter, Cobb crank pulley, Outlaw Engineering spacers and tb bypass, LGT 5spd, Slotted Crossdrilled rotors and ceramic pads, 11:1 compression, EGR delete, Port & Polished heads, SaikoMichi catch can, A/c delete. |
#1852
Within the last 30 days,,,
New front CV axles New front brakes and rotors, Transmission filter change with drain and fill Both rear bearings replaced Replaced spark plugs Drain and refill both diffs |
#1853
Got my car back from the shop today, but only for the weekend...
My SVX decided to eat the right front tire from the inside, which is what started this adventure: New right front tire... 4 New struts and mounts. Front right axle. Power steering pump. Alignment. Engine mounts. Perrin Lightweight crank pulley. Had the PWR radiator dropped to make the PWR cap fit. QS component kevlar/teflon rod ends for nevin's rear swaybar. Oil change, front diff oil, coolant, & ATF for power steering. Has to go back Monday for some piece for the left front caliper, it jingles.. They say it has no effect on the driveability.. So I told them order the part. After having everything else fixed, this one last jingle is driving me crazy.. This only my second set of repairs I have had to do on the the car in the 3 years I have owned it. I am now into her for $3,200 in repairs total, not to bad at all for a 21 year old car. |
#1854
Hope you're getting that one new tire "cut" to match the others. Otherwise, you're going to be in for more repairs.
#1855
But binding is fun!
#1856
I was wondering the same thing. So how do you cut a tire?
When I was in school I sucked in sports. Then I found out I can buy trophies and now I am great at everything. |
#1857
So is replacing the transmission when it craps out because you cheap out on tires
#1858
My "old" tires are at 9/32 of the 10/32, Subaru specs say withing 2/32, so the new one did not need to be shaved.
It is my weekend car, take it out Friday and Saturday nights in the summer only. I don't think I have even 5000miles on them. Conn, if your tires have lost more than 2/32 thread depth, you order it from tire rack and have them shave the 1 tire down to match your tread depth. Last edited by Lookin4SVX; 05-11-2013 at 11:17 PM. |
#1859
That is great! I'm over $18K so far, and that is all mechanical.
Father of 5 sons and 1 daughter Subaru SVX for fun Hyundai Veracruz for the wife. Susuki SX4 for my older son Ford Ranger for work Mercedes Benz Sprinter for vacation trips, EZ GO Golf cart for driving kids around gated community. |
#1860
I did this today to my SVX:
Just rolled over to 200,000 miles and the mechanic says the engine is still solid. |
