#1861
Drilled slotted rotors, front swaybar and end links, o2 sensors, knock sensors, Waterpump, timing belt, front differential, wheel bearings, ac compressor with R134a conversion, power steering rack, transmission, PWR radiator, ECUtune chip, Quick shift kit, new OEM windshield, and a bunch of misc other stuff were all done before I bought it. The stack of records that came with the car blew my mind, everything back to and including the window sticker.. |
#1862
The actual term is "tire shaving" and is done for a variety of reasons. Do a search for more information and videos
Here is one article; http://www.tirerack.com/winter/tech/...-d7d9e91df371& I had to replace one of my Toyo Proxes 4 after 11,000 miles due to a road hazard. My tire dealer, Radial Tire (who does shaving) Electronically measured the circumferences of my 3 good tires and entered it into his machine. We mounted the new Proxes4 tire onto the rim, inflated to the proper PSI and measured the circumference. Then entered the circumference on my other tires and the machine "shaved" off the tread evenly until it matched the other 3 exactly. Much cheaper than replacing all the tires. Tire Rack offers this service to its customers. About $25.00-$35.00 each http://blog.tirerack.com/blog/motors...e-at-tire-rack .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ... 203,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 05-12-2013 at 12:53 AM. |
#1863
DANNMARR. Doesn't take long to get $20,0 00 into a car. Mine has more than that into it cosmetically and Machanical.
When I was in school I sucked in sports. Then I found out I can buy trophies and now I am great at everything. |
#1864
changed front diff, rear diff, tranny and oil. gave her a good vacuum and was surprised to see how well she cleaned up.
1994 SVX LSi JDM Tailbar and Grill, Clear Corners, 15min-mod, Nevin Blue RSB, G-FORCE SPORT COMP-2 Tires, Phenolic Spacers (Manifold & Throttle Body), SS Brake Lines, Maniac Electric Motors 160A Alternator 2008 Legacy 3.0R |
#1865
So I decided to see how well an 18x9.5, +38 rim with a 265/35/18 tire would fit on my car. As it turns out, not that well
Yes, the quarter panel is sitting on the tire. I was surprised nothing crumbled. I'm debating how best to make these fit. Ideally I would like a bit more offset - I can put my whole hand between the coilover body and the tire. More offset would also make my wheel bearings less hateful of me. Unfortunately I don't think Rota sells a higher offset version of the Grid in that width. If I was rolling in money there is a variant of the Volk TE37 (the "authentic" version of the Grid) with more offset, but $1000/wheel is a little much for me. I do need to add camber, which will help. Currently I'm actually running +0.1 degree, so dialing in -1.5 or so will definitely help fitment as well as make the car handle better. Something else I'm debating is rounding the top of the wheel well. Since I'm replacing these panels anyway I'll just carve a slice out of them as I go and see how it looks. I would like to close the wheel well as a whole, the front and back are too much open space.
#1866
Sears has buy 3 get 1 free on Goodyear Eagle GT's, so my car is getting some new shoes tomorrow
Bought them: They look nice! Gonna take it for a longer drive today to see how they perform. Total came out to $401 with road hazard protection on them (and with the amount of construction that goes on here, it may be needed). Not bad considering most places were charging $500-$600 for the same setup. Last edited by reberto; 05-14-2013 at 01:09 PM. |
#1867
these are BOMB! maybe in 8" width?
Teamwork makes the Dream work! |
#1868
Replaced the transmission as it ate the flexplate, TQ and other fun stuff.
#1869
Wheeldude sells them in 18x8.5 +44, but I want to have some fun and be a little rediculous. My BBS wheels are 8" wide and running 245 width tires already. I want moar rubber! I could put a 275 on that wheel, but I'm planning on getting a set of Dunlop Star Specs which are notorious for being wider than their specified dimension.
#1870
Was going to change my oil yesterday along with my new tires, but my new oil container is too tall to fit under my car (5.5 inches of ground clearance my ass, more like 4.5-5), so I'm gonna grab some Rhino Ramps today. RWD car owners seem to hate them, but AWD/4WD/FWD owners have no problems with them
#1871
i use those ramps all the time. If your doing it in a garage or something with a smooth surface put some rugs/mats under the ramps to hold them while you drive up.
my only issue is after the car is on the ramps, the rear bumper is way too low for me to get a jack under it.
#1872
Dropped the tranny X-member on my '92 Legacy to swap out the vehicle speed sensor #1 and the tranny mount came apart in my hands. Had an SVX mount handy but they're not interchangeable.... D'oh!
#1873
Also, thank goodness you're replacing those panels. Looking at that rust made me cringe.
1992 Dark Teal LS-L w/ 165k+ miles (traded ) Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs 2001 Black Toyota Sequoia (hauler/daily) 1992 Blue Toyota Cressida (drift car) 1992 Red Toyota MR2 (weekend/track day car) |
#1874
New headlight and timing belt on my Legacy daily driver.
#1875
Swapped the OEM am/fm cd cassette in the '97 for a fully functional one I got from Geoff 2 years ago for the price of shipping $15.00.
Thanks again Geoff! P.S. Thanks David (SVXdc) for the How To. |
