#2191
Got a quote for left and right quarter panel replacement. Wow it all gets pretty expensive.
1992 LSL ebony pearl 170k - Thank you Ron Mummert Reading Box of Wine Car ----------------------------------- 1992 SVX LSL 5-Speed Sold at 180K 2019 1995 SVX Lsi Polo Sold at 118K 2007 |
#2192
Daniel,
What is the story with the OEM circular display.. some funny digits there?. Quote:
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. |
#2193
I will replace it at some point when I can find a good one. Works fine when on. |
#2194
My brother just did this to my parents' Forester:
Epic mother****ing facepalm. He's fine. Dumbass kid.
#2195
wow, im glad he is fine though.
#2196
Fresh timing belt, Evo III 16g turdblower for autocross, new injectors, Fuel pump, and front mount.
****'s getting serious. Also bought my old SVX back as a winter beater.
http://i840.photobucket.com/albums/z...93705d9zzz.png Last edited by Chuckls; 01-24-2014 at 11:33 AM. |
#2197
Changed the upper hose on a leaky steering rack with 4 clamps instead of 2, fresh new ATF fluid, adjusted my new exhaust system a little bit (was causing rattling), and sprayed the welds with heat resistance exhaust spray. Changed the left side booth for the steering rack. Need to keep my eye on it and see if the seals are leaking too in the next couple of days.
Next: Installing my electrically retractable mirrors and switch, along with replacing broken power window switches. Installing my leftover Nissan Nismo Horns ![]() Next next: Wiring my homelink Nissan Z mirror inside the SVX (Yeah... I am driving the best of two words). Next next next: Installing my JDM SVX steering wheel. Next next next next............. next: never ending project ![]()
Danny 1994 Silver SVX in hybernation, awaiting for the monsterous awakening (Lebanon) ![]() 1967 Mercedes-Benz 250SL Euro Specs, Hard/Softtop, White/Red. Under Complete Restoration ![]() 2013 Mercedes-Benz SL350 Euro Specs, White/Red. Mint... Another step into SL Collection. ![]() Last edited by SilverSpear; 01-27-2014 at 05:45 AM. |
#2198
1994 SVX LSi JDM Tailbar and Grill, Clear Corners, 15min-mod, Nevin Blue RSB, G-FORCE SPORT COMP-2 Tires, Phenolic Spacers (Manifold & Throttle Body), SS Brake Lines, Maniac Electric Motors 160A Alternator 2008 Legacy 3.0R |
#2199
Click on the link, you will reach the vendor. Wait until i install them and will let you know if they sound good or not.
Everything i am installing right now, I've had them since ages ago.... As for Hella, most of them are being manufactured in India now. Installed a set in my mom's Merc. They sound awkward a little bit.
Danny 1994 Silver SVX in hybernation, awaiting for the monsterous awakening (Lebanon) ![]() 1967 Mercedes-Benz 250SL Euro Specs, Hard/Softtop, White/Red. Under Complete Restoration ![]() 2013 Mercedes-Benz SL350 Euro Specs, White/Red. Mint... Another step into SL Collection. ![]() |
#2200
However, newsvx installed a set of "freeway blasters" (or something like that) on his 97 and they definitely have a better and more serious sound. Maybe he can take photos or supply more information. They both fit into the factory location in front of the battery and look OEM. I may take out my Hellas and go with these... .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . |
#2201
Hmmm... yeah it figures. The difference between your car and mine is that yours is stock/OEM upgrades, mine has nothing to do anymore with stock. But those Nissans look awesome.
Another option for you John, OEM nissan Z horns look very much alike the OEM SVX horns and they sound very very good. Google them if you want.
#2202
Had the random stalling going on for the last week especially while accelerating. Finally got the code 23 last night so put on my spare MAF sensor. Good to go. Having all this stock of spare parts on the garage shelves is awesome!!!
Elazar '08 ML550 daily driver '13 F150 work truck '87 MR2 racecar '92 Lsl Claret 5sp "Be kind to your motor car." - Jackie Stewart |
#2203
I had to adjust the tension pulley for the accessory belt. It was sitting incorrectly in the slot. If you know what I'm talking about, then you know what a pita it is to do, especially when you remove the pulley and try to put it back on.
Father of 5 sons and 1 daughter Subaru SVX for fun Hyundai Veracruz for the wife. Susuki SX4 for my older son Ford Ranger for work Mercedes Benz Sprinter for vacation trips, EZ GO Golf cart for driving kids around gated community. |
#2204
Replaced rear diff bushings. here is the old ones
![]() the new ![]() |
#2205
Not today, but recently....
Yesterday, I spent $10.00 at the coin op car wash.. Actually got on my knees to hose the salt out from underneath her ( I have NEVER done that with any car I've ever owned ).. I feel so damn guilty every time I drive when the roads have been salted. Since new, it's never seen salt, and I wanted to keep it that way. But, my boy needed my WRX, so there wansn't much choice. This following is a "cut and paste" .. I have every receipt since day one, but, since my mechanic is "cash friendly", I just keep a record of bucks spent. 97 SVX Files 29/11/13 Safety Check required one marker light bulb. Changed oil and filter. Added 1/8 bottle “Sea Foam” to engine oil ( noisy lifter ) Seepage of anti-freeze noted on right hand side head gasket. Added friction modifier to trans fluid. ( lazy 2/3 shift ) full four wheel alignment. 243,000 $200.00 05/12/13 CEL for #2 Knock sensor came back ( code previously cleared to check for repeat ) 244,200 12/12/13 Re-set Brake band ¼ turn tighter / replaced trans in line filter / changed 4 litres Mobil1 Full Synthetic Trans fluid. Adjusted parking brakes. Replaced knock sensor. 244,400 $340.00 21/12/13 CEL came on ( -26 celsius ) code showed EGR. Cleared code to check for repeat...Did not return. Write it off as stoopid effin cold. 244,650 N/C 07/01/14 245,000 In extreme cold (-25c), getting very mild surging on light acceleration off idle. Goes away once temp gauge starts to move. Purchased OBD code reader as CEL was on again. Code for EGR was back. Cleared code and booked appt., to service EGR valve, tighten brake band and check TPS for .50 V and replace RH headlight pig tail. $240.00 Code reader 10/01/14 245,100 Left car running after ice storm, all electrics on. Didn't drive anywhere. Did that twice, the third time, car died in driveway. Alternator can't keep up to demand on low idle. Regular battery will match for size, but doesn't show as applicable for SVX. Either $150.00 and no warranty, or $299.00 for deep cycle and high cranking amps. Bought the high output. $339.00 14/01/14 Raffi hooked up the meter wrong, and couldn't get a proper reading from the TPS, he did however, clean the throttle body and cleared the EGR valve passageways. replaced r/h headlight pig tail. $240.00 24/01/14 Spoke tro Raffi re: stripping Steve's (from London) and keepin a few parts/.. He's good to go on that. 27/01/14 “stop lamp out” showing on dash / installed new bulb. $3.00 |
