Old 08-02-2014, 09:05 AM
SVX_MY_BABY's Avatar
Originally Posted by ShaneHobson View Post
Intention will be to sell it once it is road legal, preferably to an enthusiast who will complete the restoration.
Body is in quite good condition.
Great to save another one.
Love the passenger side wheels.
Peter
Old 08-02-2014, 02:30 PM
How could someone turn a SVX with such a good body into a dumpster?
Glad you are working on bringing it back to life. I know there are not many around in your part of the world. Where on earth will you find the parts to fix it?
Old 08-02-2014, 10:39 PM
ShaneHobson ShaneHobson is offline
I have two parts cars and another which I'm undecided about. So I should be ok for parts.
Got it running today. Fuel pump was seized, had to extract it from the gas tank and unseize it. Car started easily and idled smoothly. Not bad considering it probably hadn't been run in 5 years and the petrol was rotten (smelled terrible).
Now I just need to get a new radiator and scrounge a pulley then I can get it home for a proper clean.
Old 08-02-2014, 10:41 PM
theflystyle's Avatar
For the Legacy --- front axles, front endlinks, and front oil axle seals...
For the SVX --- picked up some neoprene to make my own taillight seals to keep the water out.
1994 SVX LSi
2008 Legacy 3.0R
Old 08-09-2014, 10:06 PM
Removed the boot (trunk) carpets from the two cars I bought from a plasterer and took them to Wash World where I water blasted them to clean out the plaster.
They're now hanging in my shed to dry out.
Old 08-10-2014, 06:26 AM
gwynethh's Avatar
gwynethh gwynethh is offline
Tested our spare HVAC unit that we had replaced the normal green/yellow switch LEDs with blue/yellow to go with our interior theme. Good time to do that as the HVAC plug pigtails are very short and previous radio removal makes repeated testing easier. Found a couple of issues: 1 the LED legs need to be shortened as 7 of the 10 prevent proper button presses (the LEDs sit inside the switches and can prevent full presses) and 2 they actually may be too bright. Max height above the board can't exceed 15mm.
Shortening will be easy, will have to decide about the brightness but a bit of black sharpie application to the LEDs might resolve that issue. We found the blue/yellow LEDs on ebay. Memory says they are common cathode.
Photos after we shorten the legs and trail install the unit again.
Old 08-11-2014, 06:45 AM
gwynethh's Avatar
Photo of the test attached. No bezel yet but that is a minor installation. Blue LEDS are much bluer then they appear in the photo
Old 08-17-2014, 08:58 PM
AlcyoneSVX's Avatar
Alcyone Silver Contributor
Finally did the "Starter Relay Fix" on the "Black Beauty"! No more "click". It was so easy. I can't believe I waited so long! Thanks Izack!
ARMANDO
2004 Mazda RX-8
1974 Mazda RX-4
Old 08-17-2014, 10:02 PM
michael's Avatar
michael michael is offline
What Potholes ???
Got a link for that?
Wanted: Steering Wheel
Old 08-18-2014, 08:53 AM
AlcyoneSVX's Avatar
Here's the thread. The diagram I followed is in post #111.
http://www.subaru-svx.net/forum/show...rter+relay+mod
ARMANDO
2004 Mazda RX-8
1974 Mazda RX-4
Old 08-22-2014, 01:05 AM
Drove my spare Ruby 4WS home from the mechanic after getting it mobile.
Will strip & clean interior this weekend and take it for a safety inspection next week to find out what else is needed.
Now sat down in front of my big telly, watching Grand Prix [1966].
Three hours of 1960's epic F1 car racing, woo hoo !
Old 08-22-2014, 07:12 AM
Finally installed the QS Teflon end link rod ends to replace the Nevin kit ones. What a difference. I can actually hear the engine now instead of those busted and rusted rod ends.
I just hope they last.
1994 SVX LSi
2008 Legacy 3.0R
Old 08-23-2014, 02:49 AM
danielparker danielparker is offline
Well today I got my 92 SVX back after being off the road for 3 months.. I had the following done:
Engine removed and all rubber hoses replaced.
Cam Belt, Water Pump, Idlers etc replaced.
Replaced knock sensors
Upgraded Flexplate
NGK Iridium Spark Plugs
K&N Air Filter
Transmission cooler added.
EBC Redstuff Brake Pads
Steel Braided Brake Lines
Left front wheel bearing replaced.
Fluids etc replaced.
Probably more stuff that I cant remember.
Braking is now 1000% better than before.. Its awesome.
Also recently won this auction:
http://www.ebay.com/itm/enkei-17-sho...orig_cvip=true
Now I have to get them from Florida to New Zealand (8000 Miles)..
Fun times..
Old 08-24-2014, 02:29 AM
24hrs later and its bad news..
Today by heater core failed, and dumped coolant through my interior, under my passenger seat. Thankfully it was spotted (Green coolant dripping from the car.. couldn't be seen internally) and I managed to get the ABS computer extracted before it got drowned.
Many thanks to Shane Hobson for is assistance today.. Im convinced this is all his fault though.. we only discussed this exact scenario a few hours before it happened.
Old 08-24-2014, 09:29 AM
'E''s Avatar
'E' 'E' is offline
You can smell the coolant when it starts to leak before it let's go completely, it's about to happen in my red one. I should bypass it before I end up having a coolant sauna lol
92 pearl SVX about to revive
92 Black 4ws (Jap spec) SVX
93 black SVX
93 Liquid Silver SVX - sti 6 speed with R180 diff, my05 sti steering wheel, sti alloy lateral links, 19x8.5 275/30 42mm offset front and 19x8.5 275/30 22mm offset on the rear, 6 pot brembo caliper with 355 rotors front, 2 pot brembos rear
95 bright red SVX
96 emerald pearl SVX about to revive
