#2446
Shane Hobson, your AC controller is back up & running - ready to pick up when you want - from you know where....
Daniel Parker, you can send yours to me as I said in my email..... This will be the 6th AC controller I have fixed with the same issue......
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. |
#2447
Put a new radiator in my parts car today which fixed the overheating issues (previous owner installed an Impreza radiator). It's officially been upgraded from "parts car" to "winter beater" status now. It still has lots of rust and 277k miles so unfortunately it's days are likely numbered. It does have a 4.44 swap though.
Jon 1997 SVX LSi Bordeaux Pearl 1995 SVX L AWD Polo Green - 277k miles 1986 Pontiac Fiero 3.4L Twin Dual Cam V6 Last edited by Coan; 08-24-2014 at 10:18 PM. |
#2448
Popped in to visit Carl, but he wasn't home.
Bumped into him at the local BurgerFuel. Hi Carl. |
#2449
Hada rusted out power steering line replaced with a new one that has cooling fins attached. Really tight fit between the radiator and a/c condenser.
Peter ART Cryogenic/Slotted Rotors, Stainless Steel Brake Lines, PWR Radiator, Tranny cooler, Stebro, Earthworm's Poly Differential/front & rear swaybar bushings, Koni Inserts and Mychailo SVX Sport Springs all 4 corners, Indigo Blue paint. Liquid Silver Wheels. |
#2450
My svx hates me... Or at least it's trying to cook me. I finally got around to fixing the iris valve by removing the intake. Broke the purge control valve in the process. No big deal. Started driving home and the Ac tensioner locked up. Thought my repair had snookered the works, nope, unrelated. Then today the window switch got stuck or something and the regulator started making this cool noise I couldn't locate right away. Busted! No Ac and I can't roll the drivers window down! Back to driving the Xt-6....
~Phil 94 Front Wheel Magic SVX 89 XT-6 EZ30 6 speed 79 Subaru FE 97 Impreza sport flintstone edition 78 BRAT! 76 Alfa Romero GTV |
#2451
Entered the PPG Pace Car into a Subaru Only Car Show in Florence, KY About 150 Subarus....Was the only SVX there, and the oldest car...
![]() Got a "Top 15" Trophy....so I hope I represented us well ![]()
Huck Subaru Ambassador 92 SVX LS-Tour Magnaflow Exhaust, 5-Spd-AWD ![]() 88 XT6 AWD 5-Speed "Bride of FrankenWedge" 15 Impreza Premium Sedan 15 Crosstrek XV 5-Speed My 5-Speed "How-To" Write-up 1976 Pontiac Firebird Formula Current Count of Subaru's Owned.... "70" |
#2452
6spd installed in the Laguna!!
Tranny goes in, tranny comes out, tranny goes in.....AW ****, tranny comes out.... |
#2453
Wow I feel bad. Got so much I want to do and the summer is fleeting by.
Good job Huck. It is a beauty. Gamely she should be great now. I am still happy with just a 5 speed. Got to get off my butt and paint my bumpers ![]()
When I was in school I sucked in sports. Then I found out I can buy trophies and now I am great at everything. |
#2454
Visited Carl a few days ago, Hi Carl.
He had 7 x SVX on his back lawn. All in very good condition. Took another look over his crashed black car, need to think about whether or not it's worth buying. Back to my restoration car (this is the one I bought about a month ago, not running (crank pulley broken), not run for 5 years, rotten petrol, boot (trunk) full of plasterboard dust & waste). Have cleaned the boot, stripped and cleaned most of the interior. Today I polished the plastic headlights (thread with photos somewhere else here, I'l link to it when done), cleaned and recoloured the seats (thread with photos elsewhere) and fitted the seats. Took it for a drive. Wicked vibration when braking at 100km/h, but this went away after a while. Everything else seems to work. Off for a safety inspection (WOF) on Tuesday. Wish me luck. |
#2455
"The things you own end up owning you. It's only after you lose everything that you're free to do anything." 92 Pearl White Ls-l (138k) Euro Headlights & Blinkers, 97 Grill, Euro Tail Lights, SS Brake Lines, Stebro Exhaust, Slotted Rotors, Classic Registration 96 Legacy Outback (206k) 5-speed 2.2 Lightweight Crank Pulley, Group N Trans & Motor Mounts SOLD Wanted: Steering Wheel Last edited by michael; 09-14-2014 at 06:22 AM. |
#2456
How are you making out with the roof. What are you doing to it?
#2457
I'm having the body shop down the street from me repaint it.
"The things you own end up owning you. It's only after you lose everything that you're free to do anything." 92 Pearl White Ls-l (138k) Euro Headlights & Blinkers, 97 Grill, Euro Tail Lights, SS Brake Lines, Stebro Exhaust, Slotted Rotors, Classic Registration 96 Legacy Outback (206k) 5-speed 2.2 Lightweight Crank Pulley, Group N Trans & Motor Mounts SOLD Wanted: Steering Wheel |
#2458
Very cool. Please post photos of the result and cost (if you don't mind).
#2459
Will do. Cost is $400 should be done tomorrow by noon.
#2460
Wow. I could drive to Scranton and have it done for cheaper than my body shop wants. I got a quote of $800 . Said big job. The sun roof has to be removed and all the roof rubber has to be lifted to paint under it. If not they said it would peal in a few years.
