#2581
Stocked up on oil for the Legacy. With a commute of 130 km (80 miles) per day I buy in bulk.
The oil in the car is going in for analysis to see what sort of change intervals I can get away with. If I can get 12-15,000 km per oil change one barrel should last me 18 months.
#2582
I replaced the o-ring at the base of the oil filler neck.....
... do you guys know if the seal on the filler cap itself can be bought separately or do I have to order the whole cap? It feels a bit hard and it seems the small oil leak I thought was the cam cover corner actually come from either the filler neck base o-ring or the cap seal. /T |
#2583
How much savings over buying quarts or gallon jugs?
1992 Dark Teal LS-L w/ 165k+ miles (traded ) Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs 2001 Black Toyota Sequoia (hauler/daily) 1992 Blue Toyota Cressida (drift car) 1992 Red Toyota MR2 (weekend/track day car) |
#2584
Not sure if you have junk yards in Finland but you can use a cap from any suby.
edit: almost any 1990's and up suby. Quote:
"The things you own end up owning you. It's only after you lose everything that you're free to do anything." 92 Pearl White Ls-l (138k) Euro Headlights & Blinkers, 97 Grill, Euro Tail Lights, SS Brake Lines, Stebro Exhaust, Slotted Rotors, Classic Registration 96 Legacy Outback (206k) 5-speed 2.2 Lightweight Crank Pulley, Group N Trans & Motor Mounts SOLD Wanted: Steering Wheel |
#2585
I got the bucket on sail for $127 so it worked out to about $6.75/liter. A normal 5L jug costs close to $50, so $10/L. The bucket should be good for 3 oil changes + top ups.
#2586
Took the car in to get the brand spanking new steering pump installed. On the way I remembered my $700 radiator leaks. Not sure if I want to try to repair it or just get another one.
Does Nate have one because the dealer can't get me any and my mechs aren't having much luck either. Also I sent ya 2 PMs regarding the hood.
#2587
1992 LSL ebony pearl 170k - Thank you Ron Mummert Reading Box of Wine Car ----------------------------------- 1992 SVX LSL 5-Speed Sold at 180K 2019 1995 SVX Lsi Polo Sold at 118K 2007 |
#2588
I would but he unfriended me. :P I need a liaison.
#2589
-- Chris Founder/Administrator SVX World Network ECU Tune (stage 1), PWR (prototype aluminum radiator) Amateur Radio - General Class - K7SVX #1 92 Teal LSl 246k (Dedicated SVX Race Car, now with 4.44 speed) #2 92 Teal LSl 125k (Retired, car rescued from a field of weeds) 2007 Impreza 2.5i Special Edition, Obsidian Black Pearl (Daily driver) 2001 Dodge Ram 2500 quad cab, Cummins turbo diesel 4x4 (race car & RV hauler) 1985 Honda VF500 Interceptor (fair weather fun commuter) Going on 11 years of NHRA bracket racing NHRA Div 6 Car/Driver # T654 (site being rebuilt, new name is www.teamsvxracing.com) 2000 1st Place Club Challenge Series 2002 3rd Place Season Track Champion, Import Racing (Firebird Raceway) 2003 4th Place Season Track Champion, Import Racing (Firebird Raceway) 2003 1st Place NW Regional Import Shootout (July 5th) 2004 1st Place Club Challenge #1 (Firebird Raceway) 2004 1st Place NHRA "King of the Track" race 2004 NHRA Gold Cup 2nd place season win 2004 Import/Sport Compact 3rd place season win 2004 Division 6 Summit/ET NHRA Race of Champions finalist competitor (Mission, BC) 2007 1st Place Import Survival #3 2007 1st Place Track Champion Import Summer Jam (Wild Street Class) 2007 1st Place Import Survival #5 2008 Club season 1st place win, Club Champion 2008 2nd Place Season Import Final. 2008 Division 6 Summit/ET NHRA Import Finals (Woodburn, Or) 2009 2nd Place Import Summer Jam (Wild Street Class) 2010 1st Place Club race #2 - 1st place Sport Compact race #1 & #2 |
#2590
If you used the oven method what temperature and how long? I've wanted to do this for a long time, BUT since the JDM corners are not exactly growing on trees I'm afraid to mess them up! The "bi-color leds" are actually called Switchback's. Will you be using 60 or 120 leds?
Sam Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners My Locker |
#2591
Don't remember on the LEDs (they are on the oem corners now and in winter storage. Plenty bright in ant case.
"Peace is the flower of justice." |
#2592
I used a propane torch. put it on "very low", heat up the cup till it's mushy, jab a pair of needle nose pliers thru it, twist and pull it out. No need to take the lens apart.
#2593
I just wait for Advance Auto sales. They usually have deals like 5 quarts of synthetic with an oil filter for $20-25. I stock up for the year on all my cars. I also have a valve drain plug on all my cars, it makes oil changes a breeze.
Father of 5 sons and 1 daughter Subaru SVX for fun Hyundai Veracruz for the wife. Susuki SX4 for my older son Ford Ranger for work Mercedes Benz Sprinter for vacation trips, EZ GO Golf cart for driving kids around gated community. |
#2594
Had my brand-spanking new steering pump installed, the guys said it didn't change the noise much. It seems the previous pumps may have corrupted my steering rack.
Sourced a clockspring. Still looking into radiators. Want to get a cheap OEM replacement while I figure out if my PWR can be repaired. Still waiting for Tomfiles to come out of hiding. Anyone heard from him?
#2595
