#256
Re: Bontrager Works 22mm rear sway bar kit
#257
Male: 14mm, 16mm, 18mm Female: 14mm, 16mm, 18mm $28.50 for a pack of 6? ,
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . |
#258
On the passenger side a 5/16" drill bit shank can pass between the banjo bolt and the stock link, BUT it POPS through! On the drivers side the clearance is just over 1/2"
#259
Yes, I emailed them regarding how they measure the size of their boots, but I think those are going to be the ones that I end up ordering.
1992 Subaru SVX LS-L 1995 Subaru SVX LSi |
#260
At 2:18secs in the video, Is this the noise that the noisy endlinks make??? |
#261
http://www.subaru-svx.net/forum/show...light=sway+bar This is why my bar is out of the vehicle until a good resolution has been found.
If it ain't broken it, doesn't have enough features!!! '92 SVX LSL '03 4Runner '96 FZJ80 Landcruiser '90 Mercedes 300E |
#262
My best estimate for the length of Nevin's bar, outside to outside, is 122.5 cm or 48 1/4". The bar is difficult to measure on the car with the lateral links, suspension and drive train in the way but that is my best measurement. The more I look at this the more I am concerned for it does appear that there is little room between the outside bolt and the banjo bolt. How difficult would it be to bend Nevin's bar to create more clearance? Ray |
#263
Shot of my right rear endlink from the original installation. car on lift.
But whose is this? I found this on my computer. Looks like a problem but can't figure it out from the photo. Looks like the end link bolt and the banjo bolt are almost touching. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 10-14-2011 at 08:29 AM. |
#264
Jurt spoke with Larry Singer (Larry III). He has the uninstalled swaybar he won at Reading in his basement.
He is going to take an exact end-to-end measurement at the outside of the flat ends and get back to me or post here. .
#265
Great idea, good work. Ray |
#266
By request, I've come out of my Webbatical (no forums or Facebook for a week, just to see what it's like - and it's nice) to offer my take on Nevin's bar.
My clearance is comparable to John's - no chance of hitting the brakes. My endlinks provided no noise, and I would have noticed in my former car - the exhaust was stock and functional. I would say that it had no ill effects in those regards. Regarding the tail happy nature of the car after the bar is installed, YES IT WILL LOOSEN THE BACK END UP. This is what these bars do! They cut understeer, and depending on your springs, they will invoke oversteer. If you're shopping for outright safety, it was installed at the factory. If you are hunting for neutral steer as your balance and can resist the temptation to hurl your car around in the wet (which is as dumb an idea with the stock bar, all told) then the bar will benefit you. There's no doubt in my mind that the bar will have a more pronounced effect as you lean toward stock springs. With the 450/385 springs on the Silver, it retained a touch of understeer, but the power and DCCD more than make up for that. With the 385/315 springs, it found a very neutral handling characteristic, and I'd find that to be more than safe for any sensible driver to use. I can't speak for stock springs combined with the bar, but I don't know that I'd try it unless I wanted things to loosen up substantially. It's a great product. I'd say that giving Ground Control a call first is a good idea, though, and that knowing enough about suspension tuning to be able to choose springs to match this bar and natural frequencies and steer characteristics would also benefit you. Bits and pieces are chosen in specific measurements for a reason, and in my local community, I know only one other guy who's done the math behind his spring choices. John, what's the driver's side of the unknown car's bar look like? Quote:
I hope that helps, John. Back into my Webbatical! (Did I mention it's nice there?)
Disclaimer: The above post is on the internet. |
#267
Wait, I just did Maybe he's having a lot of trouble making the decision of which of the 4 SVXs to put it on. .
#268
Lots of good ideas in this thread. I am sure there is a good solution out there.
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ![]() |
#269
The length of the outside of the bar end flats is 47 inches exactly, on my bar. It looks like this dimension can vary slightly based on the angle of the bends in the bar. Quote:
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 10-16-2011 at 06:54 PM. |
#270
I was curious as to what happened to the end link from an Infinity (I think?) on at least one SVX. It looked good in the pic that was posted in the past.
