#2881
Huck Subaru Ambassador 92 SVX LS-Tour Magnaflow Exhaust, 5-Spd-AWD ![]() 88 XT6 AWD 5-Speed "Bride of FrankenWedge" 15 Impreza Premium Sedan 15 Crosstrek XV 5-Speed My 5-Speed "How-To" Write-up 1976 Pontiac Firebird Formula Current Count of Subaru's Owned.... "70" |
#2882
That's why I had mine removed years ago. Drove me nuts.
Can't believe how clean your car looks underneath! Obviously no winter salted roads driving.
Peter ART Cryogenic/Slotted Rotors, Stainless Steel Brake Lines, PWR Radiator, Tranny cooler, Stebro, Earthworm's Poly Differential/front & rear swaybar bushings, Koni Inserts and Mychailo SVX Sport Springs all 4 corners, Indigo Blue paint. Liquid Silver Wheels. |
#2883
Chased down some wiring issues, fuel pump wouldn't turn on. I have had a bit of trouble with the fuel pump wiring for a while now, first the connector inside the tank to the bottom of the tank cover started to arc and melt away, replaced that connection and then the connector on the outside of the cover started doing the same thing, all on the ground wire, well now the connection under the bottom cushion of the back seat started to do this. crazy.
#2884
I think most SVX look the same as yours underneath. I just considered it apart of the factory "rust prevention system"
![]() Update us if this actually is the source of your leaks as I would rather go this route then find it to be a leaking rear main, etc.
1994 SVX LSi JDM Tailbar and Grill, Clear Corners, 15min-mod, Nevin Blue RSB, G-FORCE SPORT COMP-2 Tires, Phenolic Spacers (Manifold & Throttle Body), SS Brake Lines, Maniac Electric Motors 160A Alternator 2008 Legacy 3.0R |
#2885
Did an oil change then took it for it's annual "Rust Check" treatment.
#2886
Today report;
SVX: Washed, tire pressures checked and upped to 35 front 34 rear CRX Si: washed, dried, covered in garage. dropped insurance Civic RT4WD : changd oil, washed, added insurance, tire pressures/air 35 all around ready for winter now.
1985 Brat GL 138k 91 CRX Si 40k 91 CRX Si 155k 97 SVX Lsi 70k 2003 s2000 91 RT4WD 166K |
#2887
Winter Wheels & Tires mounted. Pre winter waxing.
#2888
Removed oem sway bar, cleaned completley and painted red just for fun. Also cleaned up alot of componets around the sway bar like thr swaybar mounts and ect. Still wish I could get her to start......
#2889
Other Subaru:
story begins over a year and a half ago with my BRAT. maybe 2 years ago. Was coming home and it got really noisy. Was the front header gaskets to the manifold. replaced the gaskets were blown out. that quieted the thing up, but not really much a daily driver, just go down the street and back mostly. Tried to go out of town again, and couldn't get my speed up. nothing coming out the back muffler for air. Cut off the muffler. Got some air, drove a little, then nothing again, cut more off. cutt everything off after the y pipe, including resonator. Pretty good for a while, but lots of rattling sounds. Notice the cat is self destructing and leaving little bits of black charoals on my driveway (heavy platinum chunks) good, everyting is breathing. But, the dreaded saga continues. rock Auto, no muffler. No biggie, I will order the midpipe. Go to rock auto, discontinued.. Go to Ebay with part number. Order the midpipe. Place I ordered from canceled the order, out of stock. Wait for paypal refund. get refund, find another place, order it. they contact me and cancel the order. Wait for paypal refund. Go to Amazon. Order the part. Order canceled.. Then Amaozn has it listed drirectly at Amazon warehouse. Order it, says order will be shipped 2 months out. Wait a month and a half, nothing. So I cancel the order. Nothing available for the BRAT. Talk with a buddy, he says put EA82 exhaust on it from a GL wagon 87 ish. Find the muffler on rockauto, walker direct fit 48 bucks. Take my change order it, Find the magnaflow stainless midpipe but not at rock auto, nothing there. Find it at a few places including Summit Racing. order placed. Thursday FED ex dropped off the muffler (also got a muffler for my RT4wd (only 2 left and soon to be same discontinued scenario) Got the delivery of the midpipe Saturday. Put BRAT backend on jakstands. Push the muffler up there. Clears the hitch, clears the bumper, clears the axle and control arm. But the hangers are all WAY OFF. unbolt the stuf of my old midpipe from header. Push the nice stainless magnaflow up there, and botl it up. Bolt the muffler to it at the back. No hangers line up, but she is up there. Going to either hava. hsop reweld new hangers, or use some bailing wire and try myself. So a EA82 exhaust, can work for a Ea81 brat.....just don't expect perfection.
#2890
took my motorcycle parts and empty boxes of off the roof, hood, trunk, and blew the dust off of it.
Eric Rebuilt P/S pump info... http://www.subaru-svx.net/forum/showthread.php?t=50918 If your car wont start info... http://www.subaru-svx.net/forum/show...ighlight=click |
#2891
Been dealing with multiple reroutes of fuel hose around the tank and some creative brake lines....
Dropped some serious $$ to have the tank dropped... yesterday all lines above it replaced with nickle copper. w00t
'92 Liquid Silver SVX - Drilled&Slotted Rotors/Canadian OEM Seat Warmers/JDM Folding Mirrors/JDM Clear Corners/Euro Glass Headlights/Euro Headlight Level Adjustment/Euro Shifter Assembly/ECUTune Chip V.1/GARAGE QUEEN! |
#2892
well just backed out the svx and let it warm up.
Then drained the oil and removed the filter filled new oil and wix 51334 filter went to write down in my log.....ooops I had been running 5w-30 Castrol full synthetic for the last 4 oil changes My last oil change was on 11-19-2015 also and tht was about 3750 miles back this time, what I bought by mistake was 10w-30 Castrol Syntec full synthetic. Going into the winter months I hope i will be okay for the very limited few times a month use in it. Damngit. I like to use the same stuff. anythoughts?
#2893
I actually DROVE my Yellow 5-Speed to work today
#2894
Synthetic works better at cold temps than conventional so that's a plus too.
Peter ART Cryogenic/Slotted Rotors, Stainless Steel Brake Lines, PWR Radiator, Tranny cooler, Stebro, Earthworm's Poly Differential/front & rear swaybar bushings, Koni Inserts and Mychailo SVX Sport Springs all 4 corners, Indigo Blue paint. Liquid Silver Wheels. Last edited by SVX_MY_BABY; 11-25-2017 at 07:41 AM. |
#2895
Just added another to my collection:
got a 91 Sport Sedan 154k one owner then a granddaughter of the family had it, who i purchased from. Drove it home 390 miles on Wednesday smoked the brakes for the first 10 miles of it, thought i was going to have to make other arrangments and not drive it. She made it home though. Now I need to get the back window replaced as a start.
