Old 02-06-2012, 09:18 PM
Re: Brittle hoses under Intake manifold
Originally Posted by Wikedjuggalo View Post
No.. isn't it past your bed time :P?
Fell asleep during Opal...
Old 02-07-2012, 07:20 AM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
Tom, got your voicemail late last night after work. PM sent
1995 POLO LSI 76K MILES SOLD
Old 02-07-2012, 07:59 AM
solarsvx solarsvx is offline
Send a message via AIM to solarsvx
did the exact same thing last week whene i was replacing my pcv valve on mine
i ended up breaking a rotted out hose in the process but i was able to get to it,
what a pita !
2008 evo x with sss package
430 hp 380 torque stock turbo with basic bolt ons
12.56 @ 109 fully weighted 3,500 lbs
Old 02-07-2012, 12:29 PM
92 SVX 92 SVX is offline
The information in this thread is great, I am planning on replacing all those lines and will be taking the manifold off this weekend. I already ordered and received
I was unsure how much I would need so I bought couple different sizes in hopefully long enough lengths.
Old 02-07-2012, 02:17 PM
^ Silicone? Where did you get it?
Old 02-07-2012, 04:13 PM
LetItSnow's Avatar
Still Cant' Say the Z-Word
What is going to kill me is the part listed as "Valve assembly-duty solenoid" 16102AA020 which is what broke.
Economically en route, courtesy of Rob's Basement-Find Loose Parts Emporium.
Old 02-07-2012, 07:56 PM
http://www.ebay.com/itm/400168403560...84.m1497.l2649
ebay where else
Old 02-11-2012, 12:30 PM
Wikedjuggalo's Avatar
Rebuilding
So... I was hoping to have the car back together today but I found another broken nipple (go figure!).
If anyone has part 16103AA010 Tank surge let me know. Driving a truck around is killing me in gas
See picture below. It the the black Square box.
Click me.
Old 02-11-2012, 01:42 PM
LetItSnow's Avatar
Pm'd ya.
678910
Old 02-15-2012, 11:27 AM
What size are the vac lines that go to the valve covers?
Old 02-15-2012, 11:40 AM
Rebuilding
I will check when I get home for you.
Old 02-29-2012, 11:14 PM
Rebuilding
so small update for anyone who might read this down the road.
I fixed it all, special thanks to Rob and Jackie from Annapolis Subaru.
Word of advice. While the pre-bent hoses are somewhat expensive, if you happened to break the hoses that go to the "AUX AIR " sensor (forgive me for not remembering the correct name, it contains 2 u bends ) you'll appreciate them. Same goes for the PCV hoses. Spend the few dollars if you want to save yourself some blood and get the pre-bent hoses. Yes you can run cut to length hoses but I had one hell of a time running them.
As it stands the SVX is back up and running and after some driving (a few miles of hot / cold driving). It seems to be running alright. It idled weird at first but I imagine that is due to almost a month of not running. I never knew how fast I could throw a wrench across a garage until now. Could someone also answer that damn phone?
Also no fuel leaks that I can see (I removed the metal lines to the fuel rails that are connected to metal vacuum lines). I did this for a reason but can't remember now, might be related to the nice knot on the side of my head.
