rotational inertia....rotational inertia......
Compare the weight of the STI rims + tires to your old set up.... -Bill
![]() My new RX-7/Dunlop SP Sport combo weighs in at a tad under 40 lbs. Hmmm..... -Chike
92 Honda CBR 600 95 Miata |
One 5MT member here, PhastSVX, trapped at 95mph during an n/a 14.59 1/4 mile run. -Chike
hey Chike, do u think I will be able to lay down trap speeds over 100mph when I finish the twin turbo?? My car will remain completely in street trim as I love the sleeepers so it will still be heavy. I hope once I am done to be able to tag mid 13's maybe even scrape into the 12's
![]() Tom |
![]() phil
~Phil Teal 1992 Subaru SVX Turbo - Sold in May 2011 to peace-frog. |
6/14.7 X 230hp = 93.87hp above stock output, or ~320+hp (assuming a perfect turbo system with no boost leaks, etc.) A drag racers *rough* rule-of-thumb is every 10hp increase = gain of 1mph in the 1/4 mile. You should therefore gain 8-9mph in your trap speed which will put you at 99.5-100.5mph in trap speed. *Understand that this is no more than conjecture as the drag racer's rule-of-thumb is far from being scientific! ![]() -Chike
in that case, I feel that I am going to be maxing out the injectors below 6lbs. I planned on racing at 8psi so that would put me even higher than that. I think i need to get the system operational and work from there to cure my fuel issues. I think maybe upgrading to some bigger injectors like LAN will be including in the stage 3 package and running an E-manage like SVXtasy has in his car. I still am going to need a co-driver if I cannot find some time on a dyno to tune it. I may dyno the car with the N/A stage 2 but I will definately dyno it with the twin turbo just for bragging rights
![]() Tom |
![]() -Chike
http://www.ricdidonato.com/Downtime/mods.htm
Link didn't work for me. This one did though:
http://www.ricdidonato.com/Downtime/mods.html (.HTML...not .HTM) ![]()
#28
-Chike
