I appreciate your offer to lend me yours. I'm going to wait to see if anyone has a dead module that they don't want back. I'll even pay for plain first class postage -- should only be a few ounces. Quote:
If you decide to go ahead and cannibalize yours for the plug, don't let me delay you.
David C. 1996 Laguna Blue Pearl SVX L AWD See my home page for SVX radio install/removal instructions and wiring harnesses |
My alarm was new-in-the-box from Subaru, and it has always given false alarms in wet weather.
Re: After market alarm install document
I hate to thread necro, but there is a starter pinout on the back harness in the trunk.
Can that be used for a remote start application? Anyone know? |
I don't suggest trying to install a remote start system in the trunk, unless there's one with a "satellite" module (with beefy relays) that goes under the steering column.
Great! That's what I thought also, appreciate the help. I will just run the wires where they need to be properly.
SUBARU SVX 92-93
WIRE COLORS LOCATION 12 VOLTS CONSTANT BLK/YEL IGNITION HARNESS IGNITION 1 RED IGNITION HARNESS IGNITION 2 RED/YEL IGNITION HARNESS IGNITION 3 N/A So I just read that on the bulldog site. I didn't think that the svx had a 2nd ignition? Mine is 94, and reading the document in here earlier, I can't see how it would be congruent??/// Anyone know? |
if you do the remote start, you should post a how to on yours. I'm curious to see how well this would work.
did you end up using the second ignition???? is it needed I'm about to hook up a viper 5901 and as far as I could see it doesn't need one, people in the past never mentioned it...
As far as I remember you MUST connect the second ignition, pretty much splice it together into the first circuit otherwise the system will not run. Initially we left mine disconnected and the system was throwing "Remote Start Error".
-Sov13t |
so just connect it to the ignition one and connect both to the stock ignition wire from the stock security system?? also did you use the ignition 1 or 2 on that aux harness??
This is an old thread but we used the info to re-replace the oem alarm and an aftermarket CompuStar unit that was current hungry. We were able to ask http://www.ae64.com/ for the mating plug and some help. Found the OEM LED to be very dim due to the voltage supplied by the Prestige unit. The OEM switch assembly has a resistor built in that we bypassed AND we replaced the rubber bung /LED with a nice bright blue 5mm LED. Looks and works super and less current drain then the CompStar unit.
"Peace is the flower of justice." Last edited by gwynethh; 08-18-2016 at 06:50 AM. |
