Old 10-22-2001, 05:24 AM
SVXtypeR
Re: Re: you nailed it svxter.
Originally posted by Seraphim
Wonders of owning the 94/5 L version of the SVX... You guys are making me want to go get the flowmaster deltaflow 40 and stick it on the SVX
Lwin
You would not want to do that....
Singned,
One who knows.
Old 10-22-2001, 11:53 AM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
Re: Re: Re: you nailed it svxter.
Singned,
One who knows.
How loud is loud? I used to have that in the 95 camaro (base model) and it made it sound better -- yes louder too. But I thought it was not that bad.
Lwin
Lwin M. Maung (Member # 147)
Current SVX: NONE
Old 10-23-2001, 05:51 AM
SVXtypeR
Re: Re: Re: Re: you nailed it svxter.
Lwin
Imagine a straight pipe cat-back. No resonator, no muffler, no tips. Now whack off *maybe* 3db.
In all honesty, the only problem that makes it unbearable is around 2000-2400 rpm. I get *serious* interior drumming under load in this range. Other than that, someone who's used to loud exhaust could live with it. Sounds AWESOME at idle and WOT (minus the resonant range mentioned above), and of course there's the cool burbling sound under engine braking.
Old 10-23-2001, 05:02 PM
immortal_suby's Avatar
Thread Killah
"and of course there's the cool burbling sound under engine braking."
Yes - that is the best part. I was sad to see that adding the glasspack made the burbling quieter on mine. I wish there was a way to keep that burbling but still quiet down the whole thing a couple notches.
Locker Link
2015 BRZ Limited 6MT
Old 10-25-2001, 11:44 AM
Lowered SVX
right now i only get that sound when....
slowing down from like 100mph. maybe when i get some time and a little cash i will play around with that. thanks for the info.
"Too much fun to drive!"
Old 09-10-2005, 01:09 PM
Thread Killah
Changed my exhaust again
Went with 2-1/4" pipes from the headers to a dual 2-1/4" in single out 2.5" high flow cat and then the same as before out back 2.5"- a glasspack and flowmaster 80.
Mellowed it out quite a bit and totally eliminated the buzzing I was getting from 2500-3000 rpm's
Also gained back some low end torque on the butt-o-meter. Seems to jump off the line better now. Not sure yet if I lost any top end.
The mechanic thought I was a moron for putting a cat back on the car.
"you think you're going to gain power by adding a cat"
I think Harvey was right - you need some kind of expansion chamber for the low rpm exhaust plug to expand.
Locker Link
Old 09-10-2005, 08:13 PM
Bwana's Avatar
Bwana Bwana is offline
*Special* Member
Send a message via AIM to Bwana
I have flowmasters on my SVX...and they sound better then any exhaust i've heard. (havent heard stebro though)
Only thing is because my resonator was straight-piped, I get some resonance at a certain RPM....which should be easily fixed by putting a resonator back in.
[/COLOR][/COLOR]-Scott My Locker
2014 Grey Ford Fusion 2.0 EcoBoost Bought: 12-5-14
2005 Silver Legacy GT Ltd 5mt. Bought: 3-3-07 Sold: 12-5-14
1996 Brilliant Red L (AWD). Bought: 6-14-04 - Sold: 3-3-07 - 15.370 @ 89.65
1992 Claret/black LS #4086 (GF's). Bought: 6-30-04 - Sold: 7-29-07
1994 Pearl White LSi Bought: 2001? Sold: 2004?
Old 09-11-2005, 11:38 AM
Thread Killah
With the 2 in 1 out cat and glasspack where the resonator used to be I have rid my exhaust note of any resonance (finally!)
I still miss the burble it had when I had no cats, no glasspack and only the flowmaster but the resonance an dvolume was too much.
Locker Link
Old 09-11-2005, 02:37 PM
mikecg's Avatar
mikecg mikecg is offline
Originally Posted by Zombie
Chances are Flowmasters would sound like poo on the SVX. I had flowmasters on an old fullsize blazer, and they sonded great, but that was a big cam big block motor. The SVX just dosn have enough cam to sound good thru a flowmaster, and flowmaster really arent that good of a performance muffler. I'd try the dynomax super turbo. It has a really nice flow thru design.... I have thought about putting in a big dynaomax muffler ebhind the cat,, and then a couple of little bullet mufflers near the back end. Not sure if that ones going to take shape tho.... I guess my point is, stay away from flowmasters unless you have a lot of cam.
A couple of use have flowmasters. Ive been told severlal times at meets that they sound less ricy then the magnaflows. I agree. To me the magna's have a tinny sound to them. However you might be able to just enlarge the pipeing after the muffler. A larger diameter can exhaust pipe can make a big difference.
Old 09-12-2005, 10:54 AM
The Stebro tone gets much lower once you lose the center cat. I wouldn't recommend losing all the cats though.
Old 09-13-2005, 08:30 AM
KCROGUEDOG
im back to add some input. ok my exhuast has a decent low tone but as i hit over 3 rpmish it goes away then comes back at 1 1/2 to 2 1/2ish. my system is dynomax and thrush. but i heard this one guys car with a really low tone and sounded awsome he had canister mufflers and i forgot the brand but they sounded good. and to believe what it was on was strange. a tiberan hyndai (spelling whoa). so my next exhuast project will be to replace the mufflers and the glass packs with canister mufflers. 4 to be exact to get rid of the packs and drop the sound. good idea bad idea input would be great. i do want to avoid the ricer sound like a motorcycle.
Old 09-13-2005, 04:41 PM
Matthewmongan's Avatar
Matthewmongan Matthewmongan is offline
no limitation as limitation
just remove the muffler and have you friend up the street bend up a "tail pipe" i think it sounds great.
Old 09-13-2005, 09:51 PM
n00b on demand's Avatar
My exhaust does that cool burbling thing now and its stock. Of course i have a big crack before my main cat . Gotta get that welded.
