Old 09-01-2003, 09:07 PM
Originally posted by ww111
I get the feeling you'd like to do this for <$100 without having to solder... So, you'll need 2 digital meters that register frequency. High end stuff like Fluke is great but expensive. You can get a meter at radio shack for quite cheap. If you don't have a meter yet, I'd sugest getting one very good meter, I've had the same fluke for over 15 years, and one beater meter (you could leave in your car)
Anyway, disconnect the sensors, plug in the meters, set to "Hz" and read the difference.
This also has the advantage of instantainious readings. Meaning no timing, calculations, or deviations due to steering angle, road camber etc.
Happy Physics!
Collins
Collins, good one !
The idea of using two meters is a viable solution if instruments can be borowed or found cheap second hand. Even if the quality/age suggests the calibration could be suspect they could be switched and a mean figure used for calculations. This should be done in any event as a check on accuracy because each meter will have a level of tolerance and these could be complimentary
