Re: IRIS Rod
If it has good top end power, above 4000, it is most likely working. Harvey.
LIttle help
ok im trying to figure out this stalling issue now that i've found my keys. Im looking at the vaccum resevoir and pulled the front vaccum line and it had vacum so i;m assuming thats good. I cant tell from the pic though what exactly is moving. is it to the left or right of the black box on the pic? I appreciate any and all help. I have absolutely no power below 4000-4500 then its a whole new vehicle. I appreciate any and all help. As a extra note.. im still throwing a code 31 (tps) and 24(by pass air control) i've set the tps and replaced and checked the bypass. Im gonna check the tps again but could having the exhaust cut at the center cat cause the bypass code? Im still waiting to find someone with a welder around here to weld up the new cat.
I think you need to replace the TPS. It just wears out and setting it will not fix it. It mess up a lot of other controls so it may be causing other problems.
I have an extra if ya need it
Tom |
i think im gonna try and set the tps again and try to fix the exhaust. The tps only has ~70k on it. Does anyone know if the exhaust or lack there of would throw the "bypass solenoid code" ? All the connections are good and the the resistance is good on them. I appreciate any and all help and i might just need to take you up on the tps offer. tanks again guys.
Did you measure the resistance of the TPS as you twist open the throttle linkage? You just need to stab two of the TPS wires with a needle (forget which two), and then you can clip on a multimeter to test the resistance as you twist open the throttle. Do it with the engine off. The resistance should smoothly vary through the entire range.
yea i took 2 tee pins and back probed the connection and the resistance smoothly changed last time i did it. Im gonna try again and see what happens. Probing wires is a last ditch effort so i try to avoid it, but it is quite a pain to use the pins.
If the valve is stuck open, you will only have the Resonate end of the IRIS working all the time. This should not affect the idling/stalling problem, but it would affect the power that it has below 4000 rpm. It would be flat till it got to a speed that allowed the Resonate system to start working, and the power would start with it. If it was stuck part open, it would degrade both, the Inerta and resonate systems. If you can pull the hose off the diaphram, and plug another piece of hose on it, you could suck on it to see if the valve moves freely. Harvey.
