I can't seem to find the ground wire for the ABS unit, can someone tell me where it is?
Unfortunately I can't help there. I've never looked at the ABS unit that close. Mine scared me once with a code 10 but that went away and never came back *knock on wood*. ABS still working perfectly.
When I had what I thought was a bad ABS ecu...the dealer told me my ground was bad and it was not the ground near the ECU.....I never found where the ground goes to in the engine compartment or fuse box..but it was bad at that end....resulting in a "non-illuminated" indicator on the ECU unit...code 0 I think.
I do have a new extra working ECU that I'll sell......I would first check or have someone check your grounds...your ECU may be fine. |
