Old 03-16-2007, 06:39 AM
Nomake Wan's Avatar
Retired
Originally Posted by JaySVX
The horn beeps 3-4 times, but like the battery is going dead. It's really difficult to tell if the alarm is armed or not, becuase i can't see the lights and it has to be perfectly silent to hear the horn. Any idea why that might be?
From what I read, the multiple quiet beeps means that it's just locking and unlocking the doors, not arming or disarming the security system.
Old 03-16-2007, 06:45 AM
JaySVX's Avatar
JaySVX JaySVX is offline
It's locking/unlocking as it's supposed to, it just sounds/looks like it's not getting enough juice, like it's hooked to a dead battery(which it's not).
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 03-16-2007, 08:14 AM
Nomake Wan's Avatar
Retired
http://www.subaru-svx.net/photos/files/How-To/27326.pdf
Section under "keyless entry" is what I was talking about. Is it like that?
Old 03-16-2007, 09:29 AM
JaySVX's Avatar
That's exactly it. Thank you. I was kinda worried it wasn't getting enough power somehow.
Old 03-16-2007, 09:59 AM
RSVX RSVX is offline
Network Design Administrator
I guess you missed this post I made earlier...
Originally Posted by RSVX
If you are getting rapid beeps, I think that means that the alarm portion is disabled... its been forever since I have messed with the stock alarm, so I am not positive on this... its either that, or it thinks a door is still open somewhere...
Life is a game. Play to win.
Old 03-16-2007, 11:30 PM
Nomake Wan's Avatar
Retired
Got a remote on the way, should be able to test my system to see if the security unit still functions properly. Will try to answer any questions I can for you, too, SVXdc.
Old 03-17-2007, 12:39 AM
SVXdc's Avatar
SVXdc SVXdc is offline
Radio wiring harness guru
If you are getting rapid beeps, I think that means that the alarm portion is disabled... its either that, or it thinks a door is still open somewhere...
One set of instructions I have says you can't do an 'active arm' until all doors are closed first.
I recall seeing somewhere that the system will flash the lights and honk oddly when it thinks the batteries in the transmitter are getting weak.
The info on cars101.com says that the system sounds multiple short beeps when you lock/unlock with the system turned off (strictly keyless entry mode, not alarm mode).
David C.
Old 03-17-2007, 01:17 AM
TRUE. If the doors or trunk are not closed when trying to arm the system, nothing happens, no beep, no flash of the parking lights.
I have never encounterd this. I have had batteries that were almost dead and this never happened. The remote batteries either have enough power to arm the system or not.
TRUE. If the SECURITY switch on the dash is turned off, when you close the door and press the remote, the horn beeps very rapidly 4-5 times to let you know the doors are locked but the alarm system is not engaged.
