Go Back   The Subaru SVX World Network > SVX Main Forums > Competition Motorsports
Old 10-29-2007, 09:21 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Originally Posted by wawazat?? View Post
Quoted for all-around coolness Awesome combo Dan. I'm rather envious. Congratulations on your new toys!!!
Todd
Looks like someone is angling to get to drive Dan's new toy...
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 10-30-2007, 07:21 AM
solarsvx solarsvx is offline
Send a message via AIM to solarsvx
great pics,
2008 evo x with sss package
430 hp 380 torque stock turbo with basic bolt ons
12.56 @ 109 fully weighted 3,500 lbs
Old 10-30-2007, 12:31 PM
shotgunslade's Avatar
If I don't get sent to Kazakhstan or some other crazy place, and if I'm successful in getting the Ultralite registered as street legal in NJ, it is my intention to bring it to Reading next April. Oops also assuming rain is not in the forecast, as the only weather accommodation in the Ultralite is a manually operated drain plug in the floor.
