Re: A battle I just can't win
I pulled every plug today. None of them had any noticeable issues. I also looked closely at each coil, boot, and wire. None of them possessed any burn marks or marks of arcing. I replaced two of the plugs because I *thought* they might have something on them.
The problem continues! This is really pissing me off.
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount ( ![]() silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear ![]() (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi |
Did you check where the plugs connect to the wiring harness?
It's really annoying that the car does it when it's cold. It affects my ability to drive to work every day. Here's a video of what the car does in the morning: http://www.youtube.com/watch?v=eX0YP5XqUw0
When you pulled the injector plugs to check try to pinpoint it was the car idling fine or was it missing?
If it was idling fine, that test wont tell you anything. The car has to be miss-firing while you pull them. Your problem deffinetly sounds more like a vac leak though. Good luck, I hope you find the cure soon! Dustin
-Dustin 1992 Ebony LS-L w/191k miles Mods: a few ![]() ![]() ![]() 1995 Brilliant Red L/AWD w/154k miles Mods: Stebro catback exhaust, K&N drop in filter, ECUtune ST1v5, 4.44, lots of JDM goodies 1992 Pearly LS-L w/154k miles Sold ![]() 2008 DGM Legacy spec.B w/245k miles Mods: Cryotune Stage3, VF52, bushings galore, STi pink springs, Bilstein HDs My Locker The only man alive who drives three "Subu SVS's".......according to my insurance company |
![]() I see by the temp it is cold, and the sound of the engine seems to die. A vacuum leak won't worry it when the throttle is open. These cold conditions put a higher demands on both the ignition and fuel systems. By the sound I would say that I don't think it is ignition, it is extremely unlikely for a number of plugs/coils to misfire together. I think it has to be a fuel problem, almost like the temp sensor is turning on and off. Not to rule out the MAF sensor as it also compensates for the temp of the air. But as it happens when it is that cold I think it has to do with the air/fuel being too lean when it is cold. Nothing definite but in that area. ![]() Harvey.
you mention the EGR... If the valve is stuck open it would cause it to run very poorly. If you can, see if the valve moves when you increase throttle slowly... Or simply make a block-off plate for the inlet to the intake manifold and try that too... There are several vaccum lines that run to and from the EGR as well... Try to trace them and make sure all are in the right place and without cracks
Tom |
I took this video this morning to show more clearly the speed vs engine rpm. The sound is quite good and you can see this stumbling and weird idling issue.
Hahaha. I totally didn't include the video. Pretty terrible of me. http://youtube.com/watch?v=Tz_MaB4yh98
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount ( ![]() silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear ![]() (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi Last edited by Manarius; 06-25-2008 at 07:36 PM. |
![]() If this doesn't happen when the engine is warm, it has to be a lean mixture. When you start the car it increases the air/fuel ratio by doing double injections, each injector fires every rev, instead of once every second rev. This is when the highest fuel flow is needed, as I believe it is lean, there might be a flow restriction. Could even be the pump running on the resistor all the time to reduce its output. Still can't tell you what it is, may be some body has some experience of a flow problem before. Harvey.
