Re: What kind of transmission cooler should I get?
You might want to check your fluid level and make sure it isn't a little high. You really shouldn't be getting up into the 200's. I know Jon has a pwr radiator and uses it's atf cooler with one of my transmissions and I think they said it was running in the 160's.
Before I installed his cooler I went on a road testup a mountain, about an 8° incline on a 53°f day cruising at 55-65 mph. The peak temp was 207°f, and averaged 188-190°f. After removing the stock in radiator cooler and installing the Imperial, the peak was 194°f, with the average being about 169°f. Buy the way,IT WAS 76-77°F outside. So, 23-24 ° hotter, and the trans was 13° cooler! The temp dropped to the "normal" 169° much quicker as well. I put the cooler between the AC condencer and the rad. The cooler size is 3/4" thick, 7,1/2" high, 15,7/8" long, with a core length of 12,1/8".
