Old 10-07-2009, 01:03 PM
Re: Kind of Bummed about talk with Body Shop Tech
I have good amount of cash to repair it now, but if it is going to be 2-3 thousand (or more), then I am not sure if it is worth doing at this time.
Old 10-07-2009, 07:30 PM
kcbsvx's Avatar
kcbsvx kcbsvx is offline
Now down to only ONE!
It might be wise to have the shop pull off the inner door panels and see if there is rust forming at the attachment points for the exterior lower door clading so you can prevent the spread of any issues there. Mike621 can probably tell you the details.
Christian-
96 SVX Lsi #821, Bordeaux Pearl, 4.44 98 Legacy Trans, Trans Resistor Mod, Dakota Digital Trans Temp Gauge on A-Pillar Pod (awesome), B&M Trans Cooler in Driver's Wheel Well, External Spin-on Trans Filter, Synthetic Fluids in Trans and Diffs, 17x7.5 Primax 695 Rims, Alcyone Rear Panel, Svxfiles' 5000 k HIDs, Clear Headlights, "BOXER6" License Plate, Hard Wired Radar Detector, 94 Power Up Window Switch, Motor Resealed, new Coil Packs, new NGK Iridium Plugs, PVC Valve, Drilled and Slotted Rotors, Gloss Black Calipers and Rotors, EBC Greenstuff Pads, SS Brake Lines, Superb TomsSVX Cat Back Exhaust... SS Resonator, Flowmaster 80 Muffler, Magnaflow Quad SS Tips, Poly Swaybar Bushings, Endlink Mod, Rear Subframe Bushing Mod. Feels great and sounds even better. Thanks to AWD, LLC.
2003 Outback llb H6 3.0 Titanium Pearl- "BOXERR" Mostly Stock
1995 Bmw 325i Conv. Calypso Red- "RBOXER" Modest Mods
2004 Sea Doo Sportster 4-tec 15' Jet Boat, 1494cc, 1454#, 155 HP= <10#/HP Stock
Old 10-07-2009, 08:01 PM
redlightningsvx's Avatar
Collision Refinishing Tech
They do rust in the inside.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 10-08-2009, 08:14 AM
Yes they do....
Old 10-08-2009, 09:08 AM
Subie59's Avatar
Subie59 Subie59 is offline
94 SVX LSI Teal
Anything can be fixed. I had my driver's side fixed about two years ago by cutting out the rust and welding in new steel. Now the passenger side is showing a little rust. Might be time to do the same on that side. Question is should you do it now before it gets any worse or just wait until the spring. Don't know the answer to that.
94 SVX LSI
2001 LegacyGT (daughter's ride now)
2005 Legacy outback XT (wife's car)
all stock and likely staying that way for now
1981 Datsun 280zxturbo summer toy
Old 10-08-2009, 09:29 AM
If you're not going to do it now, at least get it oil sprayed really well. I just oil sprayed my car last night and actually pulled the plastic cladding off the doors to coat everything underneath, and pulled the interior panel to get the inside of the door thoroughly.
Old 10-08-2009, 11:00 AM
Wikedjuggalo's Avatar
Rebuilding
You northern people and your rust......
Old 10-09-2009, 12:24 PM
Elliott's Avatar
Elliott Elliott is offline
I swear there must be brand new cars sitting in dealerships up there with rust holes in them.
My 1959 Rambler had been sitting in a junkyard since 1972 when I got it last year, the only bad rust is because of foam rubber crap like the floor mat collecting water.
Old 10-09-2009, 02:05 PM
Gamesy's Avatar
Gamesy Gamesy is offline
My friend used Rust Check on his 240 and it worked pretty good. i dont remember but arnt our cars Zinc plated/coated to keep from rusting?
Old 10-09-2009, 04:21 PM
Yes, Subaru stated;
"100% of body sheetmetal is 2-sided galvanized."
Old 10-09-2009, 04:30 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Sean,
I'm assuming you took it down to Jeff's A.B. They do rust from the inside out so fixing the rust on the outside is nothing more than a temporary fix. Might want to consider what Mike said about having a donor scrap welded in there. 5 batteries for your grinder and a trip to Harry's should get you what you need from that Purple Cash for Clunkers car which was quite solid rust wise. I'd suspect you'd get the part for $20 or so. Then when you get her all fixed up you'll want to fill those inner parts with some nice gear oil then go for a spirited drive followed by a trip to the mall or grocery store (so the excess can drip elsewhere).
Old 10-09-2009, 06:02 PM
Originally Posted by benebob View Post
Sean,
I hate to admit it, but I don't think I could do that with out help from somebody knowledgable. I know it sounds easy, but I really wouldn't know how, and would be kind of afraid of messing it up (not to mention I don't own a angle grinder). However I will stop by and ask Jeff for a quote on fixing it this way. If it sounds reasonable I may give it a shot.
Old 10-09-2009, 06:54 PM
benebob's Avatar
I can see if I can get my dewalt working again. I think the switch went. I have 3 batteries which should be close to enough. I don't have much free time in the next month but should in Nov. If you do stop in there ask him if he's got much experience with painting a fiberglass body. I'm looking to have my TVR done this winter.
Old 10-09-2009, 06:59 PM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
Yep.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
20 F150 4X4 King Ranch
FREEDOM IS NOT FREE
Old 10-10-2009, 01:36 AM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
Yes, Subaru stated;
OT, you get good driver's side (fender, door, quarter panel)?
I think ur rust will take a long time to become a hole but it just doesn't look good especially with a bright color car.
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
