Re: Confirm my problem is Alternator related
No offense taken on the knukonceptz wires. I have dealt with them many times and they are a great company. Maniac Electric Motors is also using them for their upraded wiring kits. They also have an ebay store as well, click HERE The great thing about these wires, besides their performance, is that they are super-flexible. You can route them easily as required and make tight turns. Most 4 gauge wire is hard to do this with in short runs. Look at my install and the wire from my battery to the fuse and you will see what I mean. Very short and a tight radius turn. By not having to force the wires to bend, there is less strain on the connections. See this photo below and you will see what I mean. (Ignore the AGU fuse inline in this photo, it was replaced with the Mega-fuse) You can leave the stock connections alone, maybe clean them up and tighten. Since you are adding new ones, current will follow the past of least resistance anyway. That is why I removed the old ground wires. As far as ring terminals go, they are fine if done properly. I have a hydraulic battery terminal crimper which makes for an extremely solid connection as it crimps evenly around the entire circumference. Pliers and hammers just don't work, as they just flatten and distort the connection I would test run all of my wires, cut them to length and have a good battery shop do the crimps for you. Before installing the terminals, slide some adhesive-lined shrink tubing over the wire and then put on the connectors and then seal the connection. If you take your time and do it right, you only have to do it once. A final word on fuse holders. Keep it simple and compact. You do not have a lot of space in the engine compartment to mount them in the proper location. The ones like you have shown above are fine for installs on stereo circuits and amps where you have a lot of room in the trunk or under the seats to play with. Stick with the Mega-fuse holder. Designed to be used under the hood and withstand higher temps. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ... 203,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 03-30-2011 at 07:51 AM. |
Why didn't somebody say I could just call up Maniac and have them add some cable and connectors to my order?
Oh, wait. You did. I have a friend who's much more mechanically and more so electrically inclined. He used to do custom audio installations, and now is a video engineer for a big TV company. I've already drafted his assistance, along with his extensive tool collection in doing the work. I just needed to scrape together the parts. Thanks again.
'92 LS-L "Bandit" #362 formerly dark teal, repainted by prev owner Mods: ECUTune 2v7f, Earthworm bushings, Pioneer DVD/Bluetooth phone, Infinity Reference all around, tint, 17" wheels, custom seat belt computer, velcro visor Buying parts is like car payments. Someday she'll be all mine. |
Update #2.
Finally tore into it a bit today. Found a bunch of brittle, twenty year old plastic including an alternator plug with exposed wire and insulation that came off in my hand. A quick search revealed this thread. I'm just gonna take SVXCESS's advice this time and hit up Electric Motor Services. I'll call tomorrow and see if they've all been snagged up. The parts list is stacking up. My signature is becoming a self fulfilling prophecy. I checked out the Monster battery terminals while I was out yesterday; that chintzy g'abage ain't goin under my hood. A 220K mile car doesn't need no gold plated battery terminals. Anything else I should look out for? When I saw that cable I searched the forum and found a two month old tech thread on that very part. I don't always read the tech forums, because I don't have much I can add, but I know everything that my car throws at me has happened here before. I appreciate the help I've gotten despite the apparent redundancy of my requests. I wish I had something to add to the perfect intake/exhaust thread but the forum is always a big help to me.
You have to cut them back quite a ways back to find where they become flexible again. I just cut the plug wires back as far as I could and replaced them. One of the two white wires from the power terminal on the top of the alternator is what supplies the battery. You can see how much smaller it is compared with new 4 gauge. When new twenty years ago, the wires were adequate for the needs of the SVX. Over the years, heat and corrosion and deterioration has inhibited its original ability to carry current efficiently; hence the need for the wiring upgrade. The same is true of grounds. You can buy the alternator plug with a short length of wire attached directly from Electric Motor Service in Logan, WV. Their phone number is 800- 697-6070 The part number is 050-012252 and they go for $9.53 each plus shipping with no minimum. I already ordered two more. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ... 203,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 03-30-2011 at 09:25 AM. |
SVXcess, would you(or anyone) happen to know the length on the ground wire that runs to the back of the motor? I'd like to replace it, too. It looks like 4ga.
I also think my alternator is on its way out. The indicator lights on the dash pulsate sometimes, and the headlights will do the same. The voltage output is between 12-13v, but something isn't right. I've got 2 cores to trade in for a new one.
'92 SVX LS Pearl White - 6mt |
I think you are on to something... The output voltage isn't right! Keith |
My alternator shipped yesterday and should show up tomorrow. I ordered the alt plug and am having it shipped overnight. I just spent a penny on a SPT tiedown for no good reason at all, but it is light. I wish they still made the Prodrive one.
All that's left for the shopping list is some more cable/connectors, a new battery tray and posts, and some cleaning products for when I get back in there.
In regards to the "trick" I use to dignose alternators:
"For good reason there is no evidence that a faultybattery connection while the engine is running creates problems. As designed, the regulator utilizes a separate sensing wire. This wire terminates at the distribution panel and therefore remains connected, even if the battery lead is disconnected. As a result the regulator output continues to be monitored and output is controlled, regardless of how when or why the actual battery connection is broken. The object is to directly monitor the line voltage rather than battery voltage and in this way voltage drop is accounted for." I have posted this without permission of the contact that provided the information, so unless he would like to chime in, it will remain an anonymous source. However, it is reason enough for me to continue doing my process for diagnosing alternator problems. Although, I do usually use a multimeter to better understand the issue. If the voltage regulator is failing and the alternator is putting off too much current, then disconnecting the battery will not change anything. But if the alternator is providing too little current, it will cause the car to stall out.
Cam '92 Ls-L Dark Teal 11:1 CR ECUTUNE pistons ECUTUNE .256 duration intake/exhaust cams ECUTUNE STAGE 2AV1 ECU Z32 MAF/SR20DET injectors Balanced & Blueprinted |
Yep. Something isn't right. My memory really sucks. I have 13.8v running at idle. Gear indicator light pulsating, and if you turn the blinker on, the gear indicator dims each time it blinks.
The turn signal circuit uses about 0.2V when flashing, returning to normal in-between flashes. If my normal voltage is 13.8V, it will drop to 13.6V when flashing and return to 13.8V between flashes. It is normal for the voltage drop to occur and then the alternator continues to replace what was used. If you run your fan on low or medium speed, can you hear the change in speed while operating the turn signals? Are you running the wiring upgrade or just stock wiring? .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ... 203,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . |
I have the upgraded wiring. I was just noting though that the dash and headlights pulsate, and its kind of annoying. It happens at idle, and when driving. No signals or braking is needed to make this happen.
#28
The problem is not that the battery, is dsconnected from the system, it is the instant of disconnecting the battery, that the high voltage danger occurs. If the alternator is changing the battery, say 20 amps at 13 Volts (20A x 13V is 250 watts) when it is disconnected and the current stops flowing, the voltage will rise to 260 Volts till the alternators energy is dissipated. It will be only Mille seconds, but it can damage any electronic units that are hit by this voltage. You may get away with doing 'the test' if the alternator charge is very low, but the average Joe may not realize this, and do damage to their cars electrical system by doing this test. Harvey.
#29
What makes the current rise to 260 volts? I agree that it may rise, but where did you get that number?
#30
http://www.subaru-svx.net/forum/show...6&postcount=27 Harvey.
