Re: Re: OEM Brake Pads. Where?
Or maybe they were really good back then but, like so many other things in life, have gradually declined in quality over the years. My only regret is that I can't buy genuine Mopar brake pads for my SVX because, as we all know, Mopar rules!!!! < hey! what happened to my dang windshield wipers??!!??! >
Dick ************** 1999 Legacy GT 30th Anniversary Edition 2001 Outback Sport |
Does anyone have a good photo of what the brake shims look like?
Front shims are parts 26233B (2 needed per wheel) and 26233C (1 needed per wheel). 26233B are black rubber coated. 26233C is shiny metal. http://www.subaruparts.com/diag/?mod...category=262-1 Rear shims are parts 26633 (2 needed per wheel) and 26633A (1 needed per wheel). 26633 are black rubber coated. 26633A is shiny metal. http://www.subaruparts.com/diag/?mod...category=263-1
Just ordered my pads.
http://brakewarehouse.com $95 shipped for: Front Axxis Ultimates (better than the Axxis Metalmasters) Rear Axxis Metalmasters -mike |
BTW, if anyone wants to compare the characteristics of the various Axxis pads, have a look here:
http://www.axxisbrakes.com/technical.htm
[QUOTE]Originally posted by mbtoloczko
[B] What was it in the message archive that convinced you that OEM pads were the way to go? About 2 months ago, I replaced my OEM brake pads with Axxis Deluxe Plus organic pads (as well as having the rotors turned), and I was astounded at the improvement in braking performance. I've done the same; mine are organic pads and seem to be much better than the OEM, especially if you like progressive feel to the pedal. FWIW, bill |
