#301
What I did to my SVX this weekend: Drove it. Took the silver on a 250 mile jaunt. Smooth and strong. The old gal still pulls like a freight train. (Gotta fix that rattling heat shield, though.) Frosty AC in the 97 degree heat.
dcb |
#302
You are selling it? Why?
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything |
#303
Venturing slightly off-topic:
After waiting for three years to own the Silver, when would I ever be inspired to drive the Pearly?
Disclaimer: The above post is on the internet. |
#304
#305
What's normal about that Pearly? I think the sunroof is stock...
#306
More like, what did my son do for the SVX today. Finally, some decent rear struts.
Gene ![]()
Gene and Ben 1992 SVX LS AWD 110K - Liquid Silver 1994 SVX LSi AWD 128K - White Pearl (daily driver) 1994 SVX LSi AWD 95K - Emerald Pearl (sold) 1992 SVX LS-L AWD 115K - Dark Teal 4.44 swap (sold) |
#307
Got the SVX aligned for autoX duty yesterday and today I'm bolting on the race wheels and tires for a two day autoX event this weekend. Tomorrow, some brake work and clean-up before I leave.
On the Legacy, I'm replacing the cabin air filter so she doesn't feel left out ![]()
Down to none ![]() |
#308
Painted the calipers yesterday:
And this is my "factory looking" power mode mod. Had an spare switch cluster so I put it on the right side. The parking light one is for Power Mode, and the other is still free for something in the future. Now I just need to see if I can paint them to label them different:
Elazar '08 ML550 daily driver '13 F150 work truck '87 MR2 racecar '92 Lsl Claret 5sp "Be kind to your motor car." - Jackie Stewart |
#309
Mine is the thumb button on the shifter
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ![]() |
#311
Well I replaced the leaking power steering pump from my burgundy 92 with the pump from my 92 parts car..only to find out that it is also leaking from somewhere else that I have not investigated yet.
On a more positive note I picked my ebony 96 up the other day from they paint shop. And no I did not get a Maaco paint job either. Spent $5,000 and well worth it. They took every single teenie tiny dent out and painted my windshield wipers and the guy even took my impossible to remove water spots off my windows. The paint job has a lifetime warranty for anything weather related like oxidation. ![]()
Meow |
#312
I bought mine.
![]() Ok, It was yesterday, but hey...close enough. I'll post more later, but duty (work) calls... ~TEck |
#313
Replaced coil #2. Fixed misfire. Smooth driving.
#314
Replaced the rear diff fluid and did an oil change. Adjusted the parking brakes. Got her washed and filled with a tankful of premium and some injector cleaner for the 3 hour journey to my first autoX since 2008 and only the second time in my 5 speed SVX.
Wish me luck! Todd
#315
Glad it solved your issue.
