Go Back   The Subaru SVX World Network > SVX Main Forums > Wanted or For Sale > SVX World Network Official Group Buys > Group Buys
  #361
Old 01-07-2016, 02:59 PM
alia176 alia176 is offline
Re: Bontrager Works 22mm rear sway bar kit
Originally Posted by theflystyle View Post
Was just looking at these again and they dropped in price.. Whopping .72 cheaper!
http://www.qscomponents.com/38xmr.html
Sorry to dig this old thread up from the past!
I'm curious where are you folks purchasing the middle piece, aka Turnbuckle. I don't see this on QScomponents website.
Those of who has the complete kit, is the turnbuckle made of ALUM or Chromoly steel? I'm only finding ALUM turnbuckle everywhere!
Thanks.
'92 SVX LSL
'03 4Runner
'96 FZJ80 Landcruiser
'90 Mercedes 300E
Old 03-31-2016, 10:32 PM
Nevin's Avatar
Nevin Nevin is offline
QS components no longer makes pieces that small. They only do 1/2" and larger. No more 3/8" stuff, and they were aluminum. The endlinks themselelves were teflon coated chromoly. A pretty sweet piece, if you ask me.
I'm trying to remember the place that I had make the last batch for me.
If I think of it I will post it up here.
Jesus is the remedy
2015 Expedition EL Ecoboost
Old 01-24-2018, 01:33 PM
Svx95's Avatar
Svx95 Svx95 is offline
eg33svx95
Nevin where are you sourcing the turnbuckles? My original seized with the endliks and I'm looking to replace them.
Sam
Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners
Old 01-27-2018, 02:34 PM
Nevin's Avatar
Sam, sorry for the late reply. Oddly enough, I had a busy week!
I am getting the new ones from Rod End Supply dot com. I can source some for you, or I can just tell you the part numbers and let you do it and cut out the middle man, either way!
Nevin
Jesus is the remedy
Old 01-27-2018, 08:06 PM
Svx95's Avatar
eg33svx95
Nevin
I'll gladly take the part #
Sam
Old 01-28-2018, 02:46 PM
According to QS components, they still have the end links available.
(4) 3/8" - Chromoly Teflon/Kevlar Rod Ends @ $9.00 each.
Load Rating: 9,544 lbs.
(2) RH Rod Ends (SKU 4005755905)...LINK: https://www.qscomponents.com/collect...ale-rh-rod-end
(2) LH Rod Ends (SKU 4005755897)...LINK: https://www.qscomponents.com/collect...ale-lh-rod-end
(2) RH Jam Nuts (SKU 4005755805)...LINK: https://www.qscomponents.com/collect...t-hand-jam-nut....20 each.
(2) LH Jam Nuts (SKU 4005755804) ...LINK: https://www.qscomponents.com/collect...-hand-jam-nut#....70 each
QS Components, Inc.
Toll Free: 1-888-871-1210
Direct: 765-282-7775
Fax:765-282-6041
[/FONT]
They take Visa, MasterCard, Discover and PayPal
FREE shipping over $6.00
International orders shipped and calculated by DHL
Old 01-28-2018, 02:52 PM
Nevin,
Part numbers would be great for the end links and the barrels as well.
Did you change the barrel length? I thought they were originally 6" and then you found 5" ones.
Old 01-28-2018, 03:10 PM
QS also has the DOM steel tubing and weld-in bungs in 3/8" to make your own barrels.
DOM TUBING( by the foot)
https://www.qscomponents.com/collect...058-dom-tubing
WELD-IN BUNGS/ LH and RH
https://www.qscomponents.com/collect...eld-in-bung-05
Old 01-30-2018, 09:27 AM
Nevin,
Can you get us the necessary correct part numbers from rodends.com?
Old 07-23-2018, 08:08 PM
Subbiedoo Subbiedoo is offline
I want a rear sway bar, possibly a front too- recommendations accepted.
As this is an OLD thread, can anyone help me? Is there anyone here? Currently I'm the ONLY ONE on the website. Here's to hoping. 92svx is stock- except for new sound system, not even finished with that yet. One would think, with ALL the bloody vehicles out there, somewhere there would be at LEAST one 22mm from another vehicle that would fit.
Thank you in advance. Jim
Old 07-23-2018, 09:11 PM
Nevin's Avatar
If someone asks me the part numbers I will gladly give them out but i dont like to just publish them out in the open. If youd like you can just email me directly and i will gladly get you the part numbers.
nevinbontrager@gmail.com
And to the other question, no you can't just bolt another bar in from a differnet car. Hahah sorry
In fact, i cant imagine many cars at all that you could although im sure anything is possible.
I do not, nor do i have intentions of making, a front bar currently. The cost would far outweigh the benefit unless someone were in a crazy racing class. But then they would probably not need my help. It would cost far more because at least one side would have to be splined to work with factory mounting points but then the factory sway mounts are known to fail. Thats the reason a front bar does not exist. Unless your name is Bill. He made one.
Jesus is the remedy
Old 07-27-2018, 09:52 AM
I'm sending you a pm.
Well, I've done it before, built a 69 Ford LTD. Removed the 8" deep air box on the firewall so I could move the built 390 rearward 4", moved the AC, blower, etc to the trunk under the rear deck lid, with the battery, put the front seat in the back, Peugeot Buckets in the front, c6 shift kit, Hurst ratchet shifter, stout gas shocks, car lowered of course, 295-55frt, 310-60 in the rear(1/4" clearance! Never touched!) BEEFY sway bars for the day, fairly balanced too. look long and hard enough, and get LUCKY, I found what I needed. THE ULTIMATE test came one day JUST as I was entering a great series of 90deg sweepers. I FILLED the corvettes rear view with LTD GRILL, AND HE COULDNT SHAKE ME! (Underestimated me or he couldn't drive, or both I guess.)
Old 07-27-2018, 02:21 PM
Thanks Nevin for your input. There's 25 pages I'm trying to get through.
You seem very knowledgeable yet humble, good qualities.
I am still looking for one answer;
Are your rear sway bars still available?
Please say yes, or is it a deposit and wait? As none of those threads are recent I feel It wise to ask. I will PayPal you asap, or sooner, lol
Thank you,
Jim B.
Old 12-20-2019, 05:39 PM
SVX55 SVX55 is offline
Is it still possible to get this sway bar?
