#31
Re: SVX / Legacy radio compatibility
#32
Lincoln?
I have two of those inner cages. One is the same as yours, the other has a 14-pin plug. I thought the 14-pin one was from a UK SVX and the other was from a Legacy. But it appears I had them mixed up.
Subaru ECU and TCU Website 1992 Alcyone SVX Version L 1992 Alcyone SVX Version L 1994 Alcyone SVX S40-II 2004 Subaru Legacy 2.5 SE Sports Tourer 1996 Subaru Legacy 2.2 GX Wagon 1988 Subaru Justy J12 SL-II |
#33
Of the five wires coming into the connector, only three of them get connected to the unit. These are the blue with pink stripe on one side on its own, the black over on the other side and the brown with the red stripe. These two are on the opposite side of the connector. The two redundant wires are red [or pink maybe?] with a black stripe and a plain red wire. Do I understand you that possibly one of these unused pair could be used for a dimmer connection? And the other is possibly a live for an aerial feed? So the smaller connector has 7 positions as you note. 5 wires are connected to it with two empty positions. 3 of the 5 are picked up by the unit. The larger connector would be a 9 position model using the same logic. In this car it has 8 wires to it and one empty position in the centre. I have a 95 UK car with the exact same radio, and I would presume it has the exact same pair of connectors. [In fact 2 connectors for the radio side and the other black connector for the CD controller side] If there has been a change to a 14 pin harness I can only surmise that this change came with the 96/97 cars which were wired for OBD II. This would be a fundamental difference that could easily be checked with the owner. It's probably safe to assume that all early cars, 92-95, particularly 2-tone cars, are wired in the way these photos depict. I hope that's a little clearer now. Joe
#34
I had drink taken when I posted that Phil. I figured that is what you meant. Joe
#35
BTW I'm thankful you fellows were looking for help on this. I have not worked on the black car for 6 months, it has lain in a state of stripped wiring for some time while I concentrated on the other cars.
I discovered I have a family of blasted mice in the boot, and they have chewed up my upholstery foam and god knows what else! F ing bastids! Since yesterday I have caught three of them, and I'm still in angry trapping mode. Who knows what kind of damage they would have done if you guys had not been looking for information? Thank you both! Joe
#36
Pin-out table for your 7-pin harness (from the car): Code:
Pin Function Wire Color 1 +12V Accessory Brown/Red 2 Illumination + Red 3 +12V Battery Blue/Red 4 Ground Black 5 Illumination – (Dimmer) Red/Black 6 Power Antenna NC 7 unused NC Code:
1 +12V Accessory Red 2 Illumination + NC 3 +12V Battery Yellow 4 Ground Black 5 Illumination – NC 6 Power Antenna NC 7 unused NC Quote:
Illumination + is open-circuit when the lights are off, and +12V when the parking lights or headlights are on. Dimmer (Illumination –) is open-circuit when the lights are off, and a variable voltage when the lights are on. Voltage is determined by the dimmer ring on the stalk. This wire approaches 0 volts for "brightest" and +12V for dimmest (which is backwards from what you might expect). That's just the way Subaru does it. The dashboard light bulbs are connected between these two lines. Aftermarket radios that have a "dimmer" lead usually want you to connect it to the car's "Illumination +" wire. [UPDATE: Pins 2 is Illumination +, pin 5 is Dimmer (illumination –). Wire colors were/are correct.]
David C. 1996 Laguna Blue Pearl SVX L AWD See my home page for SVX radio install/removal instructions and wiring harnesses Last edited by SVXdc; 05-08-2010 at 04:14 PM. |
#37
Thanks for the info David.
Please feel free to download any of the images in my Photo Post folder if they may be of use to you on your website. Joe
#38
Yikes! Well that's definitely the first time my asking radio/wiring questions has helped with a vermin problem. But you're welcome!
David C. 1996 Laguna Blue Pearl SVX L AWD See my home page for SVX radio install/removal instructions and wiring harnesses |
#39
Heh Heh.
I have trapped three so far, and no more seem to be going for the bait, so I reckon I have won the battle. Because the rear lights were letting in some moisture I left the plugs out of the wheel-well in the boot. That's where the furniture chewing bastages got in! So anybody out there with these plugs pulled out should be wary of this problem. Joe
#40
OK David
As per your excellent advice I have now replaced the large pictures with thumbnails to make it better for those with slow connections and to ease on bandwidth usage. Thanks for the methodology, I'll be making more use of this. As for my mice, I have now caught four, and they are taking no more bait, so I think they are all gone. I think I will replace the plugs in the wheel well with metal grids that will let out moisture, but also keep out mice. That could permanently solve my problem. Joe
