Old 04-09-2014, 05:52 PM
92 SVX 92 SVX is offline
Re: 5mt writeup... Finally done
Originally Posted by Tireiron View Post
My big question is, you already have a 5mt that is setup correctly and working, why do you want to swap to a different 5mt? The WRX 5mt is no stronger than the legacy 5mt. You will not get a better final drive as the WRX final is 3.9 and the legacy is most likely 4.1. Also if the legacy 5mt breaks they are still easier to find in good condition than WRX ones.
So again, why exactly do you want to swap from one 5mt to another 5mt?
This is a good question, You said yours is 4.44 gears, which would give you the best acceleration and without lots of money/time changing out the front diff to match your current 4.44 rear would be next to impossible.
Old 04-10-2014, 08:16 AM
Depending on what year the wrx box is out of, meaning if it is a push clutch, you can convert the trans to accept a cable actuator
Old 04-10-2014, 08:20 AM
no cable activated Legacy had 4.44's, only some of the 4EAT's....there are a few 4.44 5-speeds, but only in Turbo cars, which all have hydraulic clutch set-ups....so you need to take the numbers off the sticker on your tranny next to the starter and determine what gears you're actually running....
Old 04-12-2014, 12:20 AM
jcimos's Avatar
jcimos jcimos is offline
Oh no what have i done! The reason why i am doing this is because my legacy tranny locked up on me not to long ago and my svx has been down for more then 2 weeks now. I freaked-out and went out to buy a wrx tranny thinking it would be an upgrade! I didn't know that it is actually a down grade. I believe the wrx tranny I have is a push type that has the hydraulic slave that pushes away from the firewall. So should go out and find another legacy tranny to save me the trouble?
ALL WAYS JUDO CHOPIN'
"Wait...your grill...is that chicken wire?"
Old 04-12-2014, 04:52 AM
in a 5 speed I don't think 4.44 gears are that ideal, you have to have some very high rpms just cruising down the road.
the normal wrx is about 3.9 geared if you have a hydrolic clutch already, which it seems you do then you just need to change the gears in the rear diff to match the trans you bought. Or if the wrx is 04 it might actually use 3.54 rear gears like the stock svx diff, find one and swap it out and done.
Old 04-12-2014, 07:24 AM
Subachouli Subachouli is offline
Subaru Parts Guy
The WRX transmission you are using is a pull style.
Find another Legacy transmission. If you can find the ID number from yours, post it up, and I'll be able to tell you what will work.
1994 SVX- 5MT, Deltaspeed, Stebro,Work VSXX
1994 Legacy GT
2001 Forester
2002 Impreza WRX
2005 Impreza WRX STI
Need parts?
Old 04-14-2014, 05:16 AM
Agree /\......................
Old 04-14-2014, 11:31 PM
jcimos's Avatar
Thank you guys. This sucks but its a lesson learned . I will pull my old one out soon and let you guys know the out come. So the new transmission, does it need to come from a Legacy or Legacy GT? Between what years also? Thanks
Old 04-15-2014, 05:18 AM
We will need to determine just what exact transmission you have first, before saying what you need to get one out of....post the numbers off the sticker by the starter on the bell housing, you can see it by just opening the hood....then we can find out what gearing it has, and recommend what to get a transmission out of
Old 12-09-2017, 05:40 PM
Alex-svx's Avatar
Alex-svx Alex-svx is offline
Hope my hydro set up will work, i have get the pedals inside now, what a pain hehe.
Alexander (Norway)
My subarus:
1992 Svx LSI 5-MT(3.54)
1998 Legacy BG 2.5L GX
Old 12-09-2017, 05:44 PM
Nemesis Destiny's Avatar
Nemesis Destiny Nemesis Destiny is offline
6MT STi-ified, now with R180!
Send a message via ICQ to Nemesis Destiny Send a message via MSN to Nemesis Destiny
Holy thread necro!
Haha, best of luck with the swap.
Did you actually find a 5 speed with 3.54 gearing in the front diff?
1992 LS-L Touring, Liquid Silver w/ Black, 110k mi. "Alice." Rebuilt title. Mods: WRX 6-CD changer, 17x8" Motegi LC-12 (16.5lbs), PWR rad, Perrin LCP, JDM v.8 6MT + R180, Koni + Ground Control (325f/280r), Earthworm Bushings. Awaiting resto.
1994 LSI The legendary "Shotgun Slade" 110k mi and still going strong!
2005 Outback XT Limited 5MT, Obsidian Black Pearl, 211k km, daily driver.
1999 Mazda MX5 base 5MT, Twilight Blue Metallic, 152k km. "Twilight Sparkle" Summer daily driver!
2007 Honda CR-V, some awful shade of light green *yawn*
1992 LS-L Touring, Ebony Mica, 176k kms. Parts car. SCRAPPED.
1992 LS-L, Dark Teal, 367k km. "Wintergreen" the winter beater.*SCRAPPED due to rust*
Old 12-10-2017, 04:59 PM
Alex-svx's Avatar
Originally Posted by Nemesis Destiny View Post
Holy thread necro!
Yes, the first gen turbo legacy here came whit that.
I have take out 2 tranny whit matching diff, and they both was 3.54 LSD.
Thanks, i had the 3.900 N/A tranny before.
Just the pedals that are the biggest job now.
Alexander (Norway)
My subarus:
Old 12-10-2017, 08:31 PM
Do you have the transmission code so I can look up the full list of ratios? How much are they where you live?
Old 12-20-2017, 02:31 AM
V won't be a lot of punch off. The line but good gas mileage and top end. I am not sure what the WRX 2002 I have. But mine feels perfect. Think I remember 3:90
Old 12-20-2017, 06:42 PM
USD 2002 WRX should be 3.90/3.545.
