#31
Re: Bent rear "toe-in" rod
Okay, now, didn't get a chance to work on it for a while, and this morning when I tried to pull the axle out of the differential, it appears that it disconnects inside the CV boot. Which, if correct, means I need to remove the CV boot, preferably without damaging it. So, how do I safely take off the boot band in order to remove the boot, and am I going to have to get a new boot band or will I be able to remove it without damaging it? |
#32
Just grab a pry bar and pop the CV axle out from the diff. You should not need to take off the boot to get the axle out and you should not be yanking on the axle in such a way that it could mess up the joint in the first place. The inner CV joint slides to change the length of the axle.
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ![]() |
#33
Yep. Just don't be too rough with it. I remember the driver's side one being quite a bit more difficult to pop out than the passenger side (they are a little different). I used a crowbar, came right out.
#35
Or are they just press in and go? |
#36
should just pop out and in with smooth firm pressure. don't "hammer" or "jerk" at them.
#37
They aren't like the fronts, where they just slide out after the spring pins are removed.
#38
Good to know, thanks guys.
#39
Anytime. You learn a lot from taking one apart...
#40
Okay, I got it out, thank you! Got the stupid bolt out, got the new lateral arm in and the bolt back in. Is there anything special I need to do to pop the axle back in or do I just apply force to the hub? Tap with a hammer or steady push?
#41
Steady push. Getting it in is a different challenge, since you can't really "pry" it in.
#42
good job dude! I'll be doing this project in a couple of weeks or so. I have all replacement parts ready to go.
If it ain't broken it, doesn't have enough features!!! '92 SVX LSL '03 4Runner '96 FZJ80 Landcruiser '90 Mercedes 300E |
#43
Okay, it's finished, the car's back together, I have a feeling I'm running a LOT of negative camber on my left rear wheel, but otherwise it seems to be sound. One question. What's this thing for?
![]() I put it back on but it seems pretty pointless. |
#44
How big is that thing? Doesn't look familiar.
#45
It's about two inches in diameter. It covered the nut at the front of the inner mount for the front lateral arm. Had a special washer with for tabs to hold it on.
