#31
Re: Quarter panel rust repairs
Ready for base and clear :-)
/T |
#32
Done - in the morning I will tell you what I think of the end result.
Photo right after cleaning the gun. /T |
#33
Might have been a long time since you painted a car but you have not lost your touch .. I am going to attempt painting my bumpers in the summer. If I get brave I will do the hood and roof next.
Next step I hope u got a good color match. Can't wait to see it all in one piece...
When I was in school I sucked in sports. Then I found out I can buy trophies and now I am great at everything. Last edited by Conn SVX; 04-08-2014 at 05:40 PM. |
#34
I'm hoping that color blends with the door when the masking comes off. Looks great though! : )
1992 LSL ebony pearl 170k - Thank you Ron Mummert Reading Box of Wine Car ----------------------------------- 1992 SVX LSL 5-Speed Sold at 180K 2019 1995 SVX Lsi Polo Sold at 118K 2007 |
#35
Thanks guys,
I think the door and trunk lid will be fine.... I only covered the repaired area with the base. So it's blended in those directions as it is. The bumper will be the thing to watch. The Q-panel looks fairly uniform, though. I got two small runs with the clear - need to try to polish them out, if not successful, the I need to do the clear again . Practice makes perfect. Also, I need to move the compressor outside if I ever do more of this. The cooling fan moves a ton of air and it is a major source for dust under garage conditions. /T |
#36
Color matching turned out very nicely. See bumper/fender line....
9 different ingredients, each measured to the tenth of a gram. I will let the clear cure for a month and then sand it down and buff the whole car. Almost there . /T |
#37
Interior panels and rear seat still to be installed.... and the whole car buffed at a later date.
Just hosed off all the dust and dirt.... Though not perfect, I am rather pleased with the end result. Tapani |
#38
Looks great in the photo.
Peter ART Cryogenic/Slotted Rotors, Stainless Steel Brake Lines, PWR Radiator, Tranny cooler, Stebro, Earthworm's Poly Differential/front & rear swaybar bushings, Koni Inserts and Mychailo SVX Sport Springs all 4 corners, Indigo Blue paint. Liquid Silver Wheels. |
#39
Nothing wrong with that job. A lot of work but it payed off. What is the spot on the rinsed off picture below and to the rear of the gas door?
When I was in school I sucked in sports. Then I found out I can buy trophies and now I am great at everything. |
#40
It really looks amazing especially considering what it looked like when you started.
#41
The spot you mentioned is just a reflection of sky between the tree tops . The two minor runs are very difficult to show in a photo. Let's see what I can do when I try to fix them. Rgds, Tapani |
#42
OMG. I just went back to page one. What an amazing job..
#43
Great job!
#44
Here are some pics of my repair in progress. (Next year you all will probably see me at the Reading meet minus 1 arm and 1 leg ).
Like Tapani's car in his recent rust repair thread (which turned out awesome) the inside of the quarter that meets up with outside metal of the quarter was rusted through badly. It will be replaced with a Subaru replacement panel. Here is the backside, the smaller more deteriorated piece of metal is the inner section Outside of piece Here is the cut away. The rusted section was not as extensive a Tapani's. The front of the wheel well opening below the cladding was clean. We are not going to be replacing the entire quarter panel after all, we will most likely just be using a section of it.
#45
Here is picture of the cut out on the drivers side, it's a much smaller piece to be welded in. I'm probably going to stop back intomorrow morning so I hope to get a few more pictures.
