#466
Re: Wheels that fit the SVX
would 18x8 38 offset be fine?
#467
ok thanks!
so, you think the difference between the wheel width could also be a problem? then i will sell the wheels. Last edited by fluo; 04-30-2012 at 04:07 PM. |
#468
I don't know if it is or not; I know there is some tolerance in the AWD system, and 1mm sounds like a small difference. Up to you, really.
1992 LS-L Touring, Liquid Silver w/ Black, 110k mi. "Alice." Rebuilt title. Mods: WRX 6-CD changer, 17x8" Motegi LC-12 (16.5lbs), PWR rad, Perrin LCP, JDM v.8 6MT + R180, Koni + Ground Control (325f/280r), Earthworm Bushings. Awaiting resto. 1994 LSI The legendary "Shotgun Slade" 110k mi and still going strong! 2005 Outback XT Limited 5MT, Obsidian Black Pearl, 211k km, daily driver. 1999 Mazda MX5 base 5MT, Twilight Blue Metallic, 152k km. "Twilight Sparkle" Summer daily driver! 2007 Honda CR-V, some awful shade of light green *yawn* 1992 LS-L Touring, Ebony Mica, 176k kms. Parts car. SCRAPPED. 1992 LS-L, Dark Teal, 367k km. "Wintergreen" the winter beater.*SCRAPPED due to rust* |
#469
Hi,
I installed the original 16" rims again. I drove along the Autobahn for 200km.... When i was in the city and turned left or right with low speed, the car made noise and vibrated very much. So I guess, that the center diff is damaged? After I let the car cool down, it ran perfectly. I think I will remove the legacy turbo tranny and install a sti 5mt dccd transmission. Greetings |
#470
i have a set of 4 rims like these, the only problem is 3 of the rims are 18x7.5 and 1 is 18x8... there is a list here of all the sizes offered
http://www.jdmultimate.com/product/i-180209.aspx i like how the 8 in wide rim looks on my car but im affraid it might strain suspension which one would best fit? |
#471
Price AUD$1,900 plus tyres (tyres $400 each)
Size 19x8.5 Offset +42mm front +22mm rear running 275/30's all round Brand of wheel Enkei Name of wheel rp03 mat forged (lighter then original wheels and tyres) Who sells the wheel EBay and most companies This combo gives the car a staggered look and makes it look pretty fat on the road, rear camber bolts required to tuck the wheels under the guard with these tyres but the benefit is the handling feels better when connering at speed
92 pearl SVX about to revive 92 Black 4ws (Jap spec) SVX 93 black SVX 93 Liquid Silver SVX - sti 6 speed with R180 diff, my05 sti steering wheel, sti alloy lateral links, 19x8.5 275/30 42mm offset front and 19x8.5 275/30 22mm offset on the rear, 6 pot brembo caliper with 355 rotors front, 2 pot brembos rear 95 bright red SVX 96 emerald pearl SVX about to revive |
#472
how about these?
http://www.importdpsonline.com/enkei.../i-180209.aspx i have on wheel like this but its 18x8 and i would think the 18x9 +38 would look better and more wider. the only thing im afraid of is ordering them and finding out they don't sit right on the car.. |
#473
the 18x9 rim face would move out by 35.75mm my front rim face sits 25.5mm further out (18x9 extends this by 10mm) my rear rim face sits 45.5mm further out (18x9 is 10mm less but you may still need some slight camber or remove the wheel arch lining or both)
#474
ok thanks and i could buy both front and back with +38 offset and then camber the rear ones which will make them look more staggered in the back? so how is that your front wheels have a different offset than your rear?
#475
Cause I wanted the staggered look and wanted to fill the rear arches with rim and the rear looking more concave then the front
#476
04 lexus is300 17x7" with 50 offset.
1992 SVX Pearlie: AmsOil signature synthetic 10w40 and Ea15k20 filter, Cobb crank pulley, Outlaw Engineering spacers and tb bypass, LGT 5spd, Slotted Crossdrilled rotors and ceramic pads, 11:1 compression, EGR delete, Port & Polished heads, SaikoMichi catch can, A/c delete. |
#477
svx my94 vtd EUDM -custom Spax coilovers |
#478
The pic on my signature is of the rear, but I'll dig some up
#479
#480
Going to look at wheels at a local pick and pull. What wheels should I look at?
Honda,Mazda,Lexus ,Accra what? Some suggestions please |
