#481
Re: Wheels that fit the SVX
Mazda RX8 wheels are one of my favorites...
![]() 1997 Ebony #308 113k "The Black Diva"SOLD ![]() 1992 Black over Liquid Silver 152k SOLD ![]() 1992 Ebony 251k 444 SOLD ![]() 1999 Silver SLK230 134k SOLD 1997 Green Outback 137k SOLD 2013 Honda Accord I4 SOLD 2015 Subaru Crosstrek 30k 2018 Tesla M3 30k |
#482
Ok confused as always.. 5 114. And 5 114.3and 4.5 inch are they all compatible? Looking at Mazda wheels with 5 114 bolt circle. Also if hub size is only slightly larger , I can't use the ring spacers. Will it work only using the lug nuts to keep rim central?
#483
I believe all those measurements are the same. 114.3 is often abbreviated to just 114, and is the same as 4.5 inch. Hub-centering rings come in many different sizes; you may be able to find ones to fit, but I've never looked for ones that adapt a Mazda bore to a Subaru one. You can bolt it up to be lug-centric, you just have to be more careful when tightening the nuts to avoid any vibrations.
1992 LS-L Touring, Liquid Silver w/ Black, 110k mi. "Alice." Rebuilt title. Mods: WRX 6-CD changer, 17x8" Motegi LC-12 (16.5lbs), PWR rad, Perrin LCP, JDM v.8 6MT + R180, Koni + Ground Control (325f/280r), Earthworm Bushings. Awaiting resto. 1994 LSI The legendary "Shotgun Slade" 110k mi and still going strong! 2005 Outback XT Limited 5MT, Obsidian Black Pearl, 211k km, daily driver. 1999 Mazda MX5 base 5MT, Twilight Blue Metallic, 152k km. "Twilight Sparkle" Summer daily driver! 2007 Honda CR-V, some awful shade of light green *yawn* 1992 LS-L Touring, Ebony Mica, 176k kms. Parts car. SCRAPPED. 1992 LS-L, Dark Teal, 367k km. "Wintergreen" the winter beater.*SCRAPPED due to rust* |
#484
Mazdas are good crossovers with very similiar offsets. The Mazda 3 wheels are not very wide compared to ours but that is a plus for snow tires. Mazda 6 wheels are in general wider but still not as wide as our. The Mazda center bore is 67.1mm and the Subaru is 56.1mm. Hub centric rings are cheap and will help make the wheel sit better.
1992 LSL ebony pearl 170k - Thank you Ron Mummert Reading Box of Wine Car ----------------------------------- 1992 SVX LSL 5-Speed Sold at 180K 2019 1995 SVX Lsi Polo Sold at 118K 2007 |
#485
Just thinking 56 to 67mm is 10 mm that is a 1/4 inch total or 1/8 on a side. Do they make them that thin. I have rings on my mags now. Would be great it they were the right size. They are thin. Maybe the PO remembers?just checked yes they do make them 56.3 to 66.7
#486
![]() ![]() ![]() ![]() I am going to have to roll the fenders but I believe I can make these work once I can buy some tires. |
#487
What brand/model are they?
#488
![]() So when are you going to buy some tires? You have had those a while now haven't you?
#489
Yeah I had to buy tires for the daily first, which then blew up on me so that is more money. I have been poor as of late. I am hoping very soon I can get tires and they are enkei rts 17x8.
#490
I still think you will have trouble with rubbing but I'm very interested to see what they will look like mounted on the SVX with tires.
#491
Yeah I am a little worried about rubbing, but that is mostly due to how low my car is. I hope to rectify that some as well. It is too low, lots of roads are crappy down here.
#492
Question : where do they come up with the offset #? So I measure and I get 6" no amount of calculating get a 45 . Bolt C 114.3 is 4 1/2 " and the center is 56 a little over 2" makes sense . 45?
Got my answer : you have to measure the wheel width divide by 2 then measure the distance to the rear of the rim to hub and subtract it from that figure . 45mm is 45mm from centerline Last edited by Conn SVX; 11-01-2012 at 05:38 AM. |
#493
-Dustin 1992 Ebony LS-L w/191k miles Mods: a few ![]() ![]() ![]() 1995 Brilliant Red L/AWD w/154k miles Mods: Stebro catback exhaust, K&N drop in filter, ECUtune ST1v5, 4.44, lots of JDM goodies 1992 Pearly LS-L w/154k miles Sold ![]() 2008 DGM Legacy spec.B w/245k miles Mods: Cryotune Stage3, VF52, bushings galore, STi pink springs, Bilstein HDs My Locker The only man alive who drives three "Subu SVS's".......according to my insurance company |
#494
I'm looking at changing my wheels and have found a design I like on ebay. I have read thru a lot of this thread, but just want clarification please??
The new wheel size is 17" x 7.5"; 5 x 114.3; 225/45/R17 tyres; BUT +38 offset. According to wheel offset calculators, this means the wheels will sit 17mm further from the calipers and 17mm towards the outside guards. Will this fit WITHOUT rolling in guards / using camber bolts? Here is the design ... http://www.ebay.com.au/itm/17-MAG-WH...item4abf1a49c2 Thanks! ![]() |
#495
