Old 07-22-2013, 08:38 PM
fasteract7's Avatar
fasteract7 fasteract7 is offline
Re: Wheels that fit the SVX
Originally Posted by fasteract7 View Post
RX-8 18x 8 rims, offset 52mm, with 235/40-18 Falken's on stock suspension, 1992 LS-L. No rubbing of tires in rear with empty backseat, fronts not even close to touching, with fairly aggressive cornering on mountain roads.
No rub with the 245/40-18's....? STi offset? Always like the 5 spoke look.
Old 07-25-2013, 09:37 AM
scoobydrvr scoobydrvr is offline
To those with RX8 wheels: What lug nuts did you use on those? I'm going to have to buy a set, I'm sure, because my current set is a cobbled together mess.
1996 SVX LSi : Work in progress, future garage queen
2013 Acura TSX: Mistake
Old 07-25-2013, 11:11 AM
fasteract7's Avatar
I use either 21 mm x 1.25, 60 degree stock Mazda conical regular (wider) or 12 x 1.25 tuner, "Gorilla" style conical lug nuts. The stock SVX, as you know, have flat/washer faces on them.
http://www.ebay.com/itm/12x1-25-Tune...ht_3069wt_1012
The eBay set are cheaper than the stock Mazda lugs and will fit aftermarket rims if you ever switch.
Old 07-25-2013, 11:38 AM
Thankyouthankyou!
Old 07-25-2013, 01:04 PM
fasteract7's Avatar
No problem...know anyone with a cheap resonator/rear pipe !!!
Old 07-25-2013, 01:22 PM
Nope, I'm in the same boat as you... I'll probly be getting that resonator suggested on your thread and have a muffler shop install it.
Old 07-29-2013, 09:34 AM
This would be a new product that He would have to develope/create.
Wanted to check up on this; any news? As an engineer, anything I can do to help?
Old 10-03-2013, 10:39 PM
Svx95's Avatar
Svx95 Svx95 is offline
eg33svx95
I've had these for a while, used to be silver, but I got bored with them and not having the money for new/different wheels I rattle canned them matte black. They are Velox VX-SCYTHE 17x7.5 Offset +42. Don't pay attention to all the door dings.
Sam
Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners
Old 10-17-2013, 12:33 AM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
I like them in Silver better
1995 POLO LSI 76K MILES SOLD
Old 12-25-2013, 10:26 AM
Tapani Tapani is offline
Anyone ever had anything like these?
http://asp.americanracing.com/wheels...rim&section=A#
American Racing Salt Flat Specials..... I wondern how they would look like with our offset....
/T
Old 06-11-2014, 12:55 PM
Just found this awesome link to measure if aftermarket wheels fit or not:
Will They Fit?
Old 06-11-2014, 01:36 PM
SVX92-97's Avatar
Thanks Danny!
Old 09-12-2014, 10:40 AM
Jvan Jvan is offline
I need to replace my tires because one developed a bubble. My wife wants the same Yokohama S Drive. I found 4 on CL but they're 205/40/18 not the 225/40/18 that I am using. Are the 205's too narrow for the weight of the SVX?
Old 09-12-2014, 11:37 AM
I ran 205's as my winter tires with no problem, but they were 55 profile. 40 profile will be very low and prone to a harsh ride and pothole damage.
Old 03-02-2016, 11:49 AM
I found an updated, edgy version of our OEM originals. available in 17" and 18" x 8"
114.3mm and 42mm offset. Still getting more info. about $1200.00 plus shipping. They are directional too.
