#46
![]() On second thought maybe I will just keep pushing for 350+whp, try to shave weight, and run my 255's ![]()
Former: 1994 Barcelona Red(x2), 1995 Brilliant Red, 1992 Liquid Silver, 1992 Ebony(x2), 1992 Pearl White (x2) Current: 2017 Ford Raptor 2017 Kawasaki KLR 1995 Guards Red Carrera 1995 Spec-ish Miata - track car 1957 CJ-5 |
#47
![]() ![]() Quote:
#48
the single biggest improvement in handling is bigger sway bars.
Actually, ours does better or at least just as good without the front bar attached. ![]() |
#50
also the single most unavailable upgrade to the SVX without having a one-off Tom |
#51
Less front bar will give it more front grip... more rear will give it less grip and make the understeering car more likely to want to rotate for you.
Jim
1992 Dark Teal LS-L with 4.44 swap. NC Plate "EVIL I" *Dont Fear the GEAR* 1977 Ford Pinto baby blue with 79,000 miles |
#52
![]() ![]() ![]() Tom |
#53
muawhahahahahah!
looks like i really do have something no one else has. muawhahahahaha! my friends dont call me dr. evil for nothing.
#55
Just what I'd want, a larger front sway bar so I can understeer even more! muawhahahahahaha! |
#56
you need to complete the equation.
#57
*sigh*
Jim
#58
Okay, just what an I'd want two larger bars so I can understeer exactly the same, only less predictably. Makes for a great race car! Are you living beside a meth lab with shared ventilation btw?
#59
who said anything about 2 bars? disconnecting your front bar is only transfering the weight to the rear to help balance in a backwards way. i eliminate understeer with the proper size tire and then take advantage of the benefits of having a bigger sway bar no one has obviously experienced.
#60
disconnecting the front bar with a stock suspension is like shooting yourself in the foot. To be honest Nate, i would suggest getting some seat time as is after I am done with the car and then deciding what to do that will help you more. right now it is all perspective
Tom |
