#46
When I brought gads (5 speed with 3.90 final ratio) car home from TN to VA I was consistantly pulling 27-29 mpg all highway. I did hit 30.5 mpg one tank mostly highway following the speed limit. everything is newer (stage 1v5/o2sensors/plugs/pcv) and clean intake system/throttle body.
Good o2 sensors are super important. kill hangovers! ![]()
Eric Rebuilt P/S pump info... http://www.subaru-svx.net/forum/showthread.php?t=50918 If your car wont start info... http://www.subaru-svx.net/forum/show...ighlight=click |
#47
engine light came on again and the same 8 codes....egr, all injectors, and the bypass air contol solinoed valve? wtf is that and how do i fix it? |
#48
Re: What do you guys get for MPG?
With 2 new o2 sensors and my misfire fixed, I'm getting around 18-19mpg. This is mostly city driving however. Kinda crap but what can you do...
1994 subaru svx le 112k |
#49
Mine varies quite a bit with type and speed of driving but I usually get around 29 with all freeway going 80 and around 23 city/highway. I actually get the best milelage right at 80 with flat roads. This is with premium gas. not bad for a very well used svx.
#50
30 highway over the 1300 mile drive to/from Reading IX, and 30 again on the 1000 mile trip to school. City is absolute balls though, my drives here are only about 15 minutes max, so the car is barely warmed up by the time I shut it down again.
#51
Mine still han't changed.
Peak: 35mpg (imp) 7+ year average: 24.5mpg (imp) and improving Recently got 33mpg on a road trip which included some slow driving as well. On another (stock) SVX driven from Toronto to Winnipeg I got the same milege. Drove from Thunder Bay to the opposite side of Winnipeg (745kms) on one tank of gas. Low fuel light came on at 720kms.
#52
i got 24.25 mpg on my first tank of 85 octane fuel. second best ever in the 5.5 years i've owned the green svx.
Kenneth 1997 Subaru SVX LSi "Svetlana" #185 of 640 - 09/1996 - Polo Green Pearl - 34k miles 1992 Subaru SVX LS-L "Everett" #8738 - 01/1992 - Ebony Pearl - 139k miles - 5MT shifty ![]() ![]() 1992 Subaru SVX LS-L "Sven" #1599 - 05/1991 - Claret - 168k miles - Traded 05/11/2005 ![]() 2023 Subaru Crosstrek Limited CVT - Crystal White Pearl - 2.8k miles 2021 Subaru Forester 2.5i Limited CVT - Horizon Blue Pearl - 17k miles 2023 Volkswagen Jetta S 6MT - Pure White - 2.6k miles 2020 Hyundai Ioniq Limited EV - Ceramic White - 30k miles |
#53
I am getting 19-20 MPG.
![]() I drive mostly highway. Any ideas what I should check to improve my millage?
2005 Legacy GT 2002 WRX VF22, Pinks, big TMIC and turbo back 128,*** miles ![]() My WRX's Cardomain Page |
#54
The nut behind the wheel?
#55
on a side note: "meh" is not a real word.
#56
#57
I got 17mpg on my last tank (9.01.08), all inner city short range, high rev driving. First tank with my 5mt installed so I was gunning it and noob shifting at 2500. Now I shift at around 1500-2000.
I believe my O2s are still original. 113k on the clock. I expect to fill again at the end of this month. That's right. I only fill up once a month.
"That which can be asserted without evidence can be dismissed without evidence." '92 Dark Teal SVX LS-L, >146,000m 3 pedals, 5 speeds., restoration underway. 2012 Honda Insight, slow but cute. ![]() |
#58
NGK FTW! ![]()
#59
I've been driving mine a lot since I got it a couple weeks ago and on 2 separate fill ups doing mostly city driving(85%) I've been getting 22-23.5 mpg but I don't have a belt on my a/c cuz there was no condensor when I bought it and I'm waiting to get a newer compressor since I have a 92 that takes expensive as hell r-12.
also I've got new spark plugs that I haven't put in yet and I know the air filter is pretty dirty right now |
#60
Don't know if the 10% or so methanol effects mpg here in wash st. but I have never seen more than 16-17 city, however at a steady 75 mph I have seen 27-28, I keep my machine lubed and tuned, tried cheap and expensive plugs, didn't seem to make any noticible difference, ambient temp. and elevation did seem to produce some varience tho. The colder the day the better the mpg, at least by my observance. My engine is at 160k, perhaps wear and tear also effects efficency.
