#661
I thought the whirring was an SVX feature that came standard on all models......I don't worry until it starts growling.......
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything |
#662
Well after like a year, my gas pedal finally matches the other two.
#663
Nope. This sound developed around the same time my CV boot tore, for a while only made the sound while turning, and very distinctly comes from the front left side. I can't really describe the sound, so I just say it's like if you were listening to footage of a helicopter rotor in slow motion. Kind of a deep, low whipping, like a "whomp whomp whomp".
#664
#665
Peter ART Cryogenic/Slotted Rotors, Stainless Steel Brake Lines, PWR Radiator, Tranny cooler, Stebro, Earthworm's Poly Differential/front & rear swaybar bushings, Koni Inserts and Mychailo SVX Sport Springs all 4 corners, Indigo Blue paint. Liquid Silver Wheels. |
#666
Got another one running right and back on the road. Hasn't run properly in more than 2 years and it runs, shifts and drives great!
#667
My deadlights are basically finished as I MDK'lld the center water fall grill (instaed of picking up the 97 like grills or likeness) and corners on the spare project lights that were previously restored to clarity goodness. The DDM HID's are ready to go in and will follow suit with LED switchbacks coming in the mail shortly. I think that's it for the headlights... doubt I'll mess with the high beams. Probably end up leaving the tail lamps completely alone... especially not doing any darkening on those at all.
1994 subaru svx le 112k |
#668
That looks great Clint!
Didn't do anything today as of yet as far as actual work, but did buy 115 donuts off ebay |
#669
Oil Change. Exciting, right?
http://i840.photobucket.com/albums/z...93705d9zzz.png |
#670
donuts.
#671
I know what I would do, just need to get me some parts
1995 POLO LSI 76K MILES SOLD |
#672
Put winter wiper blades on and looked at the new door speakers I have but decided it was too cold to do anything else (and thought out loud that I really, really need to get the XT6 out of my garage).
'97 SVX 'Brilliant' Reddish '94 SVX Lagina '93 SVX Less Reddish '89 XT6 '08 Impreza '18 Crosstrek Totaled '98 LGT ~180K '97 OBW ~185k '93 SVX Less Reddish Sold '89 XT6 '04 VDC Sedan Parts '89 XT6 '96 SVX |
#673
After 11 years of ownership with the passenger door closing with about a +4mm gap, I finally adjusted the striker today. She looks like a new car!
#674
Replaced upper radiator hose...
#675
Make sure and replace the other hose too. Just cause you can't see it doesn't mean it's not also getting crappy.
