#676
You have all the time in the world to give it to ya. I will not be at the subaru challenge as I proboly have class that day and/or work
Tom |
#677
LAN, this is just an idea off the top of my head, but would it be possible to put together a cheaper supercharger kit? you could design the ducting for the intake and all the brackets and so on and use like a paxton novi or something like that mounted on the front of the engine. stage3v2 perhaps? or make the roots blower the stage 4 and make this the stage3? just food for thought and was just hoping for something cheaper than 6500. anyway, good work so far and keep it up. someday you'll be getting an order from me for stage2v4.
#678
Personally, I think Micheal is doing a great job with his s/c kit....he's thinking through the engineering/fabrication in a very thorough manner. As far as cost goes, the only place I see a potential cost savings is sticking with the stock injectors in lieu of using the NISMO injectors. Given the amount of fabrication involved, I think folks are definitely going to get their money's worth.
-Bill
#680
Have you hit the dyno yet?
#681
300+ hp Will the driveline hold?
Even w/ the STi transaxle equipped SVX does anyone really think that Subaru can build a driveline strong enough to run this system reliably?
Seems to be that this is well developed in squeezing more power out of the EG33 but I predict that those who do fit this system on will be in the market for replacing almost every element of the driveline within as little as 6 months. Didn’t the stock EG33 sheer teeth off of the STi gear set? I know what the STi WRX output values are but we're also not talking about a 3500 lb car. It's exciting to have output values like this for the EG33 but I think we're all a bit excited w/o considering all the variables here. |
#682
-Bill
#683
The Sti weighs 3350 lbs so I really don't see the difference.
#684
after seeing svxfiles car and how he drives it im positive tthe 4.44eat can handel it.
#685
not to mention my car has been able to handle some serious abuse with a good amount of power...
THe 4heat trans has more than enough guts to hold LAN's Stage 3 kit and the axles are stout enough to handle that as well... The weakest points in the driveline are the front and rear differentials... The front diff can hold a good amount of power as long as it is maintained properly... the rear differential is another story... It would be much better if you upgraded to an r180 but to do this the front differential gears will need to swapped out for 3.90's if they even make them... Anyway my point is, the trans will hold it...the axles will hold it... the driveshaft should hold it... I don't see what else will be replaced... Not to mention with this style of blower used it will only make more power when the used wants it to, so just be a little user friendly thats all Tom |
#686
user friendly???? man i so wish i could get a 4.44 r180 |
#687
![]() -Chike
#688
My 4.44 front diff case cracked, but I strongly believe that a small crack had been in the case since I bought it. Either way, the rest of my trans is fine and was unaffected. -Chike
#689
... I stand corrected.
It's very exciting to think that the performace of these cars may finally match thier beauty. Upgrades aside, it's still quite impressive considering production began in '91. |
#690
Need Spare Parts?
LAN... I'm a little late.. just read all 46 pages... my eyes hurt. I have a engine in my garage that I had a piston explode in. Are you still looking for manifolds and stuff? I'm thinking of building it too.. ya know for the 14-16psi!
But let me know if you need parts. Paul |
