Old 06-15-2006, 05:07 PM
Different speed sensors.
Joe, Phil, this sounds like the reverse of the problem that -JJ- had, when he replaced his Euro box with a JDM box. Might be worth looking at what happened there. He even had the Solenoid 3 code.
Old 06-15-2006, 06:52 PM
Originally Posted by b3lha
From looking at the diagrams, you should be able to test using a digital meter set for low voltage AC.
To test sensor 1, measure the voltage across pins 9 (black) and 16 (white) of plug T2.
To test sensor 2, measure the voltage across pins 14 (black) and 15 (white) of plug T2.
In actual fact, pins 9 and 14 are grounds and are connected together, so you can measure 14-16 and 14-15 if it's easier.
The book says the voltage should be > 1 volt AC. I wouldn't expect it to be much more than that.
I think I asked you this before: Have you checked the "shield joint connector" B69 that connects all the transmission signal earths together.
You have. I did. These seem to be a number of earths conjoined together, and also a number of sleeves or shields, conected together.
They all seem OK.
So if I get greater than 1V ac, both sensors are outputting OK?
Old 06-16-2006, 02:43 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
That's how I read it.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
