Old 12-23-2008, 07:45 AM
longassname's Avatar
Just some dude.
Re: Gearshift Maps
ut oh, when you are done with that you are sure to get a request for the 2.0 turbo; they have the hitachi too.
Originally Posted by b3lha View Post
I really want to get back to playing with the TCU. But I've been distracted by another project. I'm busy helping a guy to find the parameter addresses for his Impreza EJ15 ECU. It's a Hitachi unit and the code is quite nasty.
Old 12-24-2008, 04:02 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Re: Gearshift Maps
Yeah, Probably. Although I'm surprised the 2.0 turbo parameters aren't already posted on the net somewhere.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 12-24-2008, 06:43 AM
Just some dude.
Re: Gearshift Maps
i didn't mean 2.0 i meant 2.2
Old 12-30-2008, 05:21 PM
b3lha's Avatar
Phil & Belha
Re: Gearshift Maps
Hey Michael,
I wonder if we're missing a trick with the TCU mods.
Ryan's post on the USMB seems to suggest that on his TCU, the stock rom can be disabled by a resistor cut rather than removing it completely - like on our ECU.
Originally Posted by presslab
The TCU was modified by soldering a socket onto the circuit board. I was going to use a different Legacy TCU but it had no holes to solder the socket! I'm not sure what year that TCU was. After the socket is in place, there is a 0-ohm resistor on the bottom of the board that needs to be moved to enable the new socket. The ROM chip I am using is a SST27SF512; this EEPROM is easily reprogrammed without a UV eraser.
http://www.ultimatesubaru.org/forum/...ad.php?t=93670
Any ideas?
Old 12-30-2008, 09:30 PM
Just some dude.
Re: Gearshift Maps
r432 connects the oe of the surface mount to the same driver pin that goes to the dip socket
r431 if used connects the oe of the surface mount to high
r430 connects the ce of the surface mount to ground (the ce of the dip socket is straight to ground)
r428 connects the ce of the surface mount to high
r429 pulls a14 of both pad sets high
moving the resistor from r432 to r431 will put the surface mount in output dissable mode
Hey Michael,
Any ideas?
Old 12-31-2008, 05:15 PM
b3lha's Avatar
Phil & Belha
Re: Gearshift Maps
Nice work.
I see it, the little green surface mount one in the corner with 000 stamped on it.
However, it's a very small part for an amateur like me to solder. It might actually be easier to remove the rom from the board than to disable it by moving the resistor.
Old 01-08-2009, 08:32 AM
b3lha's Avatar
Phil & Belha
Re: Gearshift Maps
Michael, I've added the above information to my website, credited to you. Is that OK?
http://www.alcyone.org.uk/ssm/tcumod.html
Old 01-08-2009, 08:36 AM
Just some dude.
Re: Gearshift Maps
sure,
I see you have a sst27sf256 in one of your pictures. Do you have a current source for them?
Old 01-08-2009, 09:03 AM
b3lha's Avatar
Phil & Belha
Re: Gearshift Maps
sure,
No. It's a sst27sf512. I got it from Calum. I think he got it from Mouser.
Old 01-08-2009, 09:06 AM
Just some dude.
Re: Gearshift Maps
ah, ya they still make those..the 256's are harder to find.
Old 01-10-2009, 07:55 AM
Just some dude.
Re: Gearshift Maps
subernatural,
Did you ever get a tcu?
Old 01-14-2009, 08:25 AM
Just some dude.
Re: Gearshift Maps
phil,
if you come up with a desire to switch between tcu software on the fly I'll be happy to give you a multi-tune adaptor.
Old 01-14-2009, 06:13 PM
b3lha's Avatar
Phil & Belha
Re: Gearshift Maps
phil,
Thanks. I might take you up on that sometime.
Old 02-23-2009, 08:51 AM
Just some dude.
Re: Gearshift Maps
bump for this being cool..come on peeps..trust me, you want to chip your tcu.
Old 02-23-2009, 12:41 PM
SuberNatural SuberNatural is offline
Re: Gearshift Maps
Im waiting on some funding lol. Like I said though, after my TCU is chipped I'll be getting a ROM off you.
1992 Liquid Silver/Black LSL
LeveL10 Stage 3 Trans and associated stuff
