#61
Re: Phenolic Intake Manifold and TB spacers for the SVX/EG33 coming soon
Ok..maybe my dyno needs some adjustment
I got the the tools and some materials ordered. They should be here in a couple of days. Going to build the fixtures this weekend to hold them on the CNC, so I should be ready to go pretty quickly. Also have to take the IM/TB off my SVX this weekend so I can see how it all goes together.
'93 Anniversary Edition SVX 122k - 3.7 FD 5MT Swap, ECUtune 1a1, Bontrager RSB, Mad Restoration underway! '20 Honda Ridgeline Custom Oil Caps, Battery Bars, Phenolic Spacers for sale here: http://www.x35design.com |
#62
Haha, I think about 4 zeros were feeling lonely so you just had to throw them in there. I'm with OT, definitely one of the best responses ever! Tell Santa I've been a good boy, as if it makes a difference.
Sam Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners My Locker |
#63
Will your phenolic spacers act as their own gaskets or will a double quantity of oem gaskets also be necessary?
"Peace is the flower of justice." |
#64
It will be double OEM gaskets. One on each side of the spacer. So 4 of the manifold to head gaskets.
#65
The IM gasket to head part # 14035AA140 (need 2 sets) The throttle body spacer gasket part # 16175AA091 (need 2)
#66
Why not just machine in o-ring grooves and do away with any question of the spacers sealing?
Bill
#67
The factory gaskets work fine and I do not know how long O-Rings will last at aproximately 170°f.
#68
Won't this work also disturb the gasket between the IMs and the intake collector? So should we also plan on pair of 14075AA021s?
#69
If you want, you can seperate the upper and lower manifold, but it is not required. You can unbolt it as one piece from the heads. So if you find it easier, or have some other reason to separate them, than definitely get the gaskets for there also.
I know on mine, now that I have the spacers and the way the supercharger is setup, I never undo the lowers from the head. Anytime I need to pull the manifold/SC I only unbolt the upper. But that is more a way to save a little money as it only requires one gasket instead of two, and I don't have to move the fuel lines or anything just to pull off the manifold. |
#70
Viton O-rings should work fine - spec out to 400 deg. F and are resistant to gasoline. Maybe a copper wire o-ring for the bottom? Would just have to replace them every time you pulled the stacks off. Bill
#71
20 ft/pounds might not be a good sealing idea. It is different on a 90 foot/pound aluminum to alunimum head gasket, for example. Copper O-Rings custom made and bent for a limited application would most likely be much more expensive than the stock Subaru gaskets. Merry Christmas. Sending PM.
#72
Hello again-
After much holiday slacking and goofing off, I will be heading to the shop tomorrow to make the fixture and first set of spacers. What material are the OEM gaskets made of? I have not pulled mine off yet, so I am not sure. O-ring groove style sealing might be possible, but would require some R&D on my end to figure it out the groove size, find a suitable o-ring, etc... How patient are you people?
#73
Idk what material the OEM gaskets are as I've never had some in my hands. I have some ordered but haven't picked them up yet. For the Intake gasket I'm quoting two guys from ultimatesubaru.org "Subaru's intake gasket is a multiple layer metalic gasket", and "Subaru's OEM intake manifold gasket, just like their headgasket is graphite impregnated metal"
I don't see a purpose for the O-ring when doubling up on gaskets works fine on the injector stacks Well, we've been waiting this long.... patient is my middle name
#74
With any luck you will never have to remove your intake manifold again. Your first factory gaskets lasted for 100+k miles.
#75
Just milling around at the shop....
'93 Anniversary Edition SVX 122k - 3.7 FD 5MT Swap, ECUtune 1a1, Bontrager RSB, Mad Restoration underway! '20 Honda Ridgeline Custom Oil Caps, Battery Bars, Phenolic Spacers for sale here: http://www.x35design.com Last edited by Stevebsy; 01-04-2015 at 04:14 PM. |
