#76
love the coil overs
1992 Pearl / Black SVX removed intake silencer, k&N pannel filter, trans cooler, 94 JDM 4eat, Noltec front swaybar mounts, Motorsport D&S disks with EBC Greenstuff pads |
#77
Guys,
Some movement, but not much. Nearly finalised the wiring...damn there's some excess wires in this car. A bunch of photos too. Clutch pedal is different for us right-hand-drive folks. The clutch pedal goes through the main hole for the engine wiring loom. This will need relocation and some fiddling to sort. The strut top photo is my new rear strut tops...exactly the same as GC8 WRX's (92-00 I think). Notice the thickness of the DMS shaft...this is why I need them for rallying. HEAPS stronger and will not bend a shaft on a big jump. The photo of the WRX column is the adaptor I needed to get it to fit. Did I tell you it was heaps lighter? |
#78
This shows the clutch pedal from the other side. Need to fabricate a top mount for it...have MIG, will travel!
M |
#79
Man, you guys have it easy when it comes to 3 pedals... Ever seen a LHD hydro assembly?? They are a mess!!. Well good luck and every looks awsome!!!
Tom |
#80
Matt,
Looks great! What are the specs on the DMS struts? (spring rates? adjustability on dampers? cost?) -Bill
#81
Bill,
DMS have 4 rebound and 16 bump adjustments. The springs are 260lbs fronts and 225lbs rears. Similar specs to his current model STi stuff as apparently the weight balance is similar. Matt |
#82
Yea, and the prices are (cover your nuts now) $3800 and change per set, not including shipping.
#83
I guess you get what you pay for?
#84
Cough....Cough....wow...let me catch my breath here
![]() Matt, Are the struts a direct bolt in, or will you have to grind the SVX's hub like Dave and Ben had to get their Impreza struts to fit? Are the rear struts adjustable once they're bolted in (hope so!)? I'm curious about the spring rates, as they're roughly 100 lbs lower, front and rear, than what folks are running with their GC coil overs. Is this just a concession to the rally aspect of the application? -Bill
#85
Bill,
These are made specifically for the SVX. The only change required is the factory SVX strut tops at the rear are not useable. However, a set of standard GC8 Impreza rear tops, or even the STI tops for the old shape WRX would work fine. I'm just using the rear tops as per my picture. So, other than the rear top, they are a direct bolt in. Adjustability is on all 4, so front and rear. As to spring rates, I believe rallying has softer springs than tarmac, but am not 100% sure. These rates are recommended by Jamie who built them...they could change if they aren't working, but we won't know that until we do some testing. Desertrunner (Anthony) also got a set for his road car...I believe the valving and spring rates may differ for his car than mine. They are expensive, but they are top shelf stuff and most definitely are not something hacked apart to fit...they are custom made for the SVX specifically. Matt |
#86
With that said however, I can completely understand the need for more in your situation, a rally suspension is much more demanding than tarmac and it also requires a much different setup. Your suspension is meeting your needs which is why the tall bill is worth paying. For a tarmac raced car, it would simply be foolish to adapt this suspension in place of the already efficient konis. So, in closing I would agree that you get what you pay for. But I must also elaborate that paying for the top shelf is not a wise decision when well liquor will do just fine... ![]() Tom |
#87
Tom,
You're entirely correct...these are required for my purposes...but would be potentially overkill in other applications. There's a saying over here..."horses for courses"...meaning what is suitable for one person, may be unsuitable for another. It's like PWR radiators, they'd be the best I'd reckon, and there are definitely cheaper alternatives, but for my needs, I'm happy to pay the $800. M |
#88
exactly why I do not recomend the PWR radiator to people looking simply for a replacement and why I tell people looking for an MT not to buy the overpriced 6mt unless you are making more power and plan on abusing it. Going straight to the top is not always the best route. I really like what you are doing with the car and I cannot wait to see how well this performs...
Tom |
#89
Horses for courses.
As Matt says, the spring rates suit the type of track that the car will run on. The actual spring rate has to be multiplied by the total strut travel. The rally car has to have a very soft initial rate to allow the wheels to keep traction on small bumps, but support the entire weight of the car over jumps, without bottoming the strut travel.
You can see by the way the spring is wound. It is progressively wound at each end, from tapered wire. This makes the rate very progressive, provides a supple ride, with a high total load. The type of track that you all "auto cross" on is smooth and flat. No bumps at all, so the ideal set up is a very high spring rate, with very little strut travel. But if this set up is used on the 'real road', small bumps will have the car lose traction and skate across the road. The standard suspension, is a low spring rate, with a long travel. Gives a supple ride, but can keep the car stable on high speed bumps, without getting out of shape. Harvey. ![]()
#90
Does this allow you to fit a quick rack to fix the rather low geared steering, driver input being the most important consideration? Cheers, Trevor.
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! ![]() |
