Go Back   The Subaru SVX World Network > SVX Main Forums > Competition Motorsports
  #76
Old 01-14-2012, 01:12 AM
jeffs92svx jeffs92svx is offline
Re: SVX Straight line performance
Just wondering, does anyone know what the difference between the awd and front wheel drive svx's are? I guess the fwd would be lighter but the awd would get the better launch.
92 claret-87 xt turbo-93 z28 6 speed-06 cobalt SS
Old 01-14-2012, 01:20 AM
hey, LAN, how much are your valve bodies? I may be interested in one. thanks.
Old 01-14-2012, 03:16 PM
http://www.ecutune.com/4eat_valve_body.htm
I've installed on in my Claret and when I can afford another it will go in my Pearlie.
Old 01-14-2012, 04:04 PM
The AWD vs FWD is only around 100 lbs difference FYI... Not worth the loss of traction.
Old 01-14-2012, 05:58 PM
If my memory is still working right.
The 1/4 record is still held by a FWD svx, Walter (poweredx2). just before the diff failed.
Old 01-14-2012, 07:01 PM
If he was "dragging" the car, he was probably trying to run a very sticky tire which would be stressing the diff very much.
I'll admit, 20-anything, a fwd SVX will blow away an awd all things equal, but off the line, in "normal" circumstances, it's way too easy to break traction in a FWD.
I was merely stating what I did because most people seem to have the misconception that the FWD SVX is "so much" lighter than an AWD, but in the same trim, there is very little weight savings.
Old 01-14-2012, 08:02 PM
IF I remember between the two axles, rear diff, driveshaft, rear crossmember,
tailshaft ir the AWD trans it is only 110 pounds.
However the gear ratio changes to an improved 3.7, rather than a 3.545.
I will HAPPILY take the AWD and the weight (wait) penalty!
Old 01-15-2012, 09:52 PM
Memory is getting a bit hazy... cracked that record long ago
Old 01-16-2012, 01:53 AM
Yes that could be right too.......I forgot about the 'blown' class. You both were.
The naturally aspirated class is held by who??????????
Old 01-16-2012, 08:02 AM
N/a is ben and dave w the racer...
Old 01-16-2012, 09:20 AM
Well, i am glad that you pointed that out because i myself thought the AWD would be much heavier. I would definately rather have my AWD instead of a FWD, though i have been running mine in FWD with the fuse in.
Old 01-16-2012, 09:51 AM
Is your trans broken? or are you trying to break it??
Old 01-16-2012, 04:08 PM
A sure way to loose the front diff.
Old 01-16-2012, 04:40 PM
What He ^ said!
Old 01-16-2012, 05:22 PM
What He ^ said!
Well luckily ,,,, he is just down the road from you, when it happens.
