Old 06-15-2011, 12:19 PM
kwren's Avatar
kwren kwren is offline
Re: NO MORE CLICK click CLICK START..ONLY START! starter relay
Originally Posted by dcarrb View Post
The click-no-start-thing revisited:
Since then I've driven it to work twice, to lunch, to the bank, to the gas station. Every time it has started on the first lick. So this probably isn't news to those of you who know about such stuff, but clearly, the trouble (at least with my car) has to do with providing adequate juice for the starter to do its thing. FWIW...
dcb
Good helpful information! Thanks for passing it along.
Keith
Old 06-16-2011, 01:08 PM
I've never "fixed" mine. The "bandaid" has been working for me for over 7 years now.
Old 07-16-2011, 02:26 PM
RHC RHC is offline
I want to sincerely thank the folks that did all the research before me. My '92 Pearlie has had this intermittent issue for the past year; it first manifested itself last July in a little Texas town on a Sunday. Fortunately, it started after a few clicks. The 'click, click, click' became more frequent over the past year and research led me to this posting.
I found the Auto Zone relay without a hitch, although they say it's an A/C relay in their computer.
The only 'down-side' to the whole operation is my 64 year old body doesn't contort to access the under dash area like it did when I was 25.
Thanks again,
Roy in AZ
Old 07-27-2011, 07:28 PM
SomethingElse's Avatar
word words wording
Thanks again,
Roy in AZ
Awesome, Im glad some people still use the search feature to find this thread.
Eric
Old 08-01-2011, 12:47 PM
gbianchi gbianchi is offline
Mine is always caused by low battery voltage, it clicks I check, its below 12, I charge she starts, although probly one day it will not, cheers all...................G
03 Baja. 05 Baja turbo
92legacywagon"snow"
94legacywagon"whinny"
84Brat"huey"
92svx"samantha".pearl
92svx"sabastian"4.44 silver
92svx"sabrina".ebony
06 Subaru legacy gt limited.
Old 08-02-2011, 01:29 PM
Got the click in my project car. Didn't click before the swap. Decided to apply the band-aid fix again since it worked perfectly the last time.
Old 08-16-2011, 01:52 PM
RHC RHC is offline
Cool Re: NO MORE CLICK click CLICK START..ONLY START! starter relay
Well... It seems as though the relay didn't fix my particular problem. I finally was able to have the 'Click, click, click' issue manifest itself when the hood was open and my trusty mechanic standing in front of the car. I appear to have a starter solenoid issue.
Old 08-16-2011, 06:50 PM
Ask your mechanic to fit a relay to the starter solenoid, as shown here.
http://svxworldforums.com/forum3/3422.html
Old 09-14-2011, 10:11 AM
Hallabalogee's Avatar
Hallabalogee Hallabalogee is offline
So after ordering 4 starters from different venders none seeming to be the right part. Noob mistake, turns out I needed one for an 04 WRX. Got her all fixed and now my rear bearing seems to be going out.
Old 04-12-2012, 02:54 PM
Where do I look next after replacing the relay and the starter switch? I have a test light hooked up to the wire going to the starter, and I'm not getting anything...
If the key is turned to run, and a jump a wire from batt + to the starter, it starts right up, so it is somewhere between the key and the starter. What else is there beside the relay and the ignition switch?
Old 04-12-2012, 04:53 PM
neutral safety switch
Current Stable:
1992 SVX
1979 K5 Blazer Cheyenne
1967 Chevy C20
1953 Chevy 210
1969 Plymouth Satellite
1949 Chevy Thriftmaster
1959 Chevy Apache
1951 Chevy Stepside
1969 Chevy Camper Special
1978 Ford F150 w/ stroked 460
1986 Volvo 740 turbo wagon
1999 GMC 2500 Creep Van
1994 Impreza Outback
Old 04-12-2012, 06:33 PM
Originally Posted by Hocrest View Post
Where do I look next after replacing the relay and the starter switch? I have a test light hooked up to the wire going to the starter, and I'm getting anything...WHAT NOTHING, OR SOMETHiNG.
If you are getting nothing, check the wiring at the gearbox inhibitor switch. Try it in Netural, the Park contacts may be burnt.
If you are getting something, you may be best to do the Bosch relay mod. to prevent all that current from burning up all the switches.
Have a look here for how to do it.
http://svxworldforums.com/view_post.php?post_id=35308
Old 04-12-2012, 09:57 PM
Sorry, I either missed a word or typed the wrong word. I'm getting nothing out to the starter when I turn the key.
I was thinking earlier tonight that I want to jump the pins on the trans harness like we do for MT swaps tomorrow and see if that the issue.
Does anyone know where the shift indicator falls in the sequence between the key and the starter??
I'll also have my SVX here tomorrow, so I can pin out the wires step by step and compare.
Old 04-12-2012, 09:58 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
It has been so long that I used the bypass mode (bandaid), I forgot there was a starter problem
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 04-12-2012, 10:35 PM
"I'm getting nothing out to the starter when I turn the key.".
It is the small wire to the solenoid that has nothng?
The sequence is, the key, security relay, Inhibitor switch on the box, starter solenoid.
Don't forget to try it in N, it case the P has a problem.
