#91
Re: Fifteen minute, $15.00 rear suspension mod.
Got any pics, Bro?
![]() I have poly bushings in the rear (and front) .. Wud I still use them? Why can't .. or don't you MOD the fronts.. ? ![]() Sure! .. . I send $$$$$$$ !!! ![]() ![]() Thanks.. ![]()
Jim 1995 Laguna Blue SVX AWD L - 240K (daily driver) - "ReBuILT" used engine at 236K miles (6/13) 2013 Veloster Red - Driver Now??Dropsprings [1/2" rear, 1" front] with Koni Strut Inserts> Magnaflow Exhaust System> ECUTune Stage 1av1 Upgrade (from 1v4)> ECUTune TCU MOD> Aluminum Crankshaft Pulley> Stainless Brake Lines> Phenolic Spacers> Perforated Brake Rotors (dint like, OEM now)> SmallCar Shift Kit (resting since TCU MOD)> 7-Position Ground System> High-Pressure Fuel Pressure Regulator (resting)> ATF Cooler & Campaign Filter> Yellow Polish Polyurethane Bushings> Pioneer Double-DIN Stereo with JL AUDIO Speakers> Driveshaft Rebuilt with C-Clip U-Joints> 15 Min MOD> 20 Min MOD .. . (2011) ![]() ![]() |
#92
http://www.subaru-svx.net/forum/show...nty+Minute+Mod
#93
Just got parts for 15 Min Mod from advanced. However one disk seems to be about 2mil thicker than the other. They are both part#31000. Would this make any difference or can I just roll with it?
#94
How thick are they?
It should be fine.
#95
About "Yay" thick. Thanks!
#96
Kids.
![]() I just opened two packages and got 0.34", and 0.32" The idea is to eleminate the gap/slop in the mounting point. ![]()
#97
Well this is definitely not a 15min job for a fwd! It appears that I have to take the sway bar loose to get the bracket loose enough to insert the new discs. Does that sound about right? I have a completely different set-up than the one you have pictured.
#98
Also, this mod would do very little for a FWD car compared to an AWD car because there's no driveline back there to need stiffening. I mean it couldn't hurt, but you shouldn't expect much.
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ![]() |
#99
just did the 15 minute mod,
my suggestion would be to use 2 car jacks one for jacking up the car, and the other for jacking up the rear crossmember. the 2nd jack take alot of the pressure off of the bolt when you are taking it off and, when puting the bolt back on it removes the slake. This makes the mod much easier than it already is to do. Then you don't have to fight with the car, and you can position the rubber spacer to where you want it. Last edited by kjoyes; 05-18-2012 at 12:31 AM. |
#101
![]() Now if we can just get the same level of common sense applied to adapting or cross-referencing consumables for our cars all will be well. -Mike O |
#102
We are finishing up our cheap suspension mods like poly bushings and the 20$ and 15$ mods. We have a problem with one of the nuts that we need to remove for the 15$ mod. We have tried PB blaster applied over 3 days with no luck. We use a 6 point socket on a normal 3/8" drive ratchet handle extended about a foot for a better pull but no luck. We are a bit concerned about breaking the male threaded piece with a stronger pull. We also don't want to heat the nut being concerned about cooking the rubber parts. We also have tried the suggestion to take the load off the nut by jacking up the arm.
The only idea we have now is to use a dremel and vertically slot the nut to open it up or split it with a small (1" dia.) cut-off wheel. Before we try this do any of you have any other ideas to get this stubborn thing free? Last edited by gwynethh; 07-30-2013 at 11:36 AM. |
#103
Advance Auto Parts has one in their big pipe expander kit. And they will loan you the kit.
#104
Having let it sit longer with the PB, I would still try and heat it a little, but not enough to smoke the bushings. Those are really strong thick bolts and will take a lot to really break. I find with PB, a little bit of heat, and an impact gun it will take them right off. I've actually never needed more than an impact gun for those bolts on any of the subarus I have worked on, and I live in new england, the rust capitol of the world.
#105
Well after several days of on and off soaking with PB Blaster and (per a neighbors recommended) Mouse Milk still no luck with an impact gun and my wimpy home use compressor. My neighbor rolled over his old school shop compressor with a bigger delivery hose and success at the same indicated delivery pressure as ours. Still need to get a new nut but that appears to it for this particular saga. Thanx to you all for: 1 the mod idea and 2 all the help getting the little pain in the neck nut free.
